Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
INTERNET CONNECTION -Trying to access internet through a secured access point. -WEP is entered properly and has association with excellent connectiveity. -In IP address DHCP I get no results -In IP address STATIC I get "web site can not be found" Is there some setting that I am missing ?
Hi im having problme in RF Scanner motorola ,while searching for wireles connection msg prompting for scann error " Adaptor not available " I did all the solution replace required dll file and reboot,cold boot,so far no solution....
Posted on Jun 14, 2010
    Novelist:
  • 75 Answers
If you have a DHCP server on your network then it would have picked up an IP. If you have setup a static IP set try and ping from a workstation on the same network to the device.
I have seen it on numerous occasions where the WEP key is not quite correct and associates with full signal strength, but there is no connectively to the network. Remove the profile and try again.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Dec 17, 2009
2 Suggested Answers
thesuperdude
  • 97 Answers
SOURCE: INTERNET CONNECTION
You will also need to go to settings>connections>advanced and ensure that on the two drop down menus you have either my network or my isp and ont one of each.
Posted on Mar 26, 2009
Internet
Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
Jun 25, 2011 | Nintendo DSi Black Console
Have problems trying to connect to the internet
Jun 24, 2011 | Nintendo DSi White Console
Dear nintendo, I'm trying to connect to the DSi shop,but I can't connect to my internet.Can you helpmeet? From...
Jun 23, 2011 | Nintendo DSi Black Console
No internet
  1. Turn on your Nintendo DSi and access your system settings by clicking on the wrench icon.
  2. Scroll over to the third page, and select "Internet."
  3. Now choose "Connection Settings."
  4. Click on "None" in "Connection 1."
  5. Then click "Search for an Access Point"
The system will then display the name of any wireless access point within range. If nothing shows up, try moving to another location.
If The access point has a gold, unlocked icon, tap the access point's name, and then "OK." The system will then establish a connection with your router.
If The access point has a gold, locked icon, the Nintendo DSi has detected WEP/WPA key security on your router:
  1. Tap the Access Point name.
  2. You can either enter your WEP Key, or click "Change Security Settings" to enter a WPA key.
  3. Tap "OK" again and the system will then establish a connection with your router.
If The access point has a gray, locked icon, the system has determined your router is set to WPA security. You need to access the Advanced Setup area of the system to connect with this security method.
  • Instead of tapping "None" in "Connection 1", click "Advanced Setup", then click "None" in "Connection 5".
Feb 15, 2011 | Nintendo Dsi Pink Console
How do i get on the internet?
Jan 30, 2011 | Nintendo DSi Blue Console
I sal a format button but did not know how to read at the time so i clicked it and then i chose to play my game but then i sal my internet was gone i'v ben trying to get it back ever sence
Below is the instructions on how to set-up your internet on your dsi, hope it helps
  1. Turn on the Nintendo DSi
  2. Click on the wrench icon to access "System Settings."
  3. Select "Internet" on the third page of System Settings.
  4. Select "Connection Settings" and tap the "None" bar in "Connection 1."
  5. You have the option of setting up a connection manually, or searching for available connections in the area. You may also access your Nintendo Wi-Fi USB connector, if you have one (the product has been discontinued). The easiest thing to do is select "Search for an Access Point."
  6. Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
  7. If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key.
  8. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify.
  9. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Hope this was helpful? Please comment for more information and thank you for using fixya.
Jan 24, 2011 | Nintendo DSi Black Console
How do you get on the internet if you don"t have
hope this helps
Dec 07, 2010 | Nintendo DSi Matte Blue Console
How do you get internet on dsi \
Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only). Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
Hope this helps
Nov 30, 2010 | Nintendo DS Lite Console
Trying to get wireless connection.everything is good until i test connection.then it says....a connection error has occurred.the attempt to obtain the ip address timed out...What do i do now????
make sure that first you have your own internet! If you do then make sure you set the your new connection to WEP setting! this allows you to put in the neccesary code to access your wireless internet! then make sure you know your code and enter it in after you set the securtiy! if you have your wireless internet set with security then you either have to know the code to access it or set it off so it doesnt block anyone from access! allowing you to use None in the WLAN security setting!
So my main point you are trying to access someone else's internet??? so if its a store then ask them for the code and set WLAN securtiy setting to WEP and put the password after its selected!!! Friends internet ask for WEP code and then samething!, or someelses internet who has a security block so people dont steal internet! gotcha
Aug 19, 2009 | Sony PlayStation Portable (PSP) Console
INTERNET CONNECTION
Aug 22, 2008 | Zebra Symbol Technologies MC909X-G Series...
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
1,105 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
