Error code 60 model# FTF2140ES3 - Washing Machines
  • 1 more comment
  • Anonymous Sep 13, 2008
    all light are flashing
  • oldblondwoma Jan 03, 2009
    The washer goes through the wash cycle then stops and all the lights flash. Won't drain. Put it on the drain/spin cycle and it goes back and forth and still won't drain.
  • chisermame Jan 07, 2009
    I have the same problem except I can turn the Wash Selection to Drain/Spin and it will drain. It will wash and drain but it just sits and hums when it gets to the Rinse cycle. What is wrong with this thing? This is the second problem we have had and we only run two loads per week in it.
I had the same problem with the water not draining. Turned out to be the internal filter was plugged with lint. Paid a tech to repair it and watched what he did. Next time (The tech says this happens every 6 month to a year) I'll do it myself.
Posted on Mar 21, 2009
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
FTF2140ES won't spin
How old is the machine ?
if about 3years old check carbon brushers
Dec 14, 2013 | Frigidaire FTF2140ES Stacking Front Load...
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
Problem :
E604 Error Code. You followed all the troubleshooting steps in the service manual and still have an E604 code.
Solution :
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity.
Jul 13, 2012 | Canon imageRUNNER 400S Copier
Ftf2140es3
How about save yourself some cash and put it on spin manually and try that see if that works.
Apr 04, 2012 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
I have a frigidaire washer, model ftf2140es3. It ...
try pressing select and option button at the same time. We had all the lights lit up but it would not start or cancel until we did that. or slam the door,,
May 16, 2010 | Washing Machines
Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Dec 02, 2009 | Frigidaire Washing Machines
F2 error code
F2 E6 says this:
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
Ftf2140es3 won't completely drain or do final spin.
I have one that does the same thing at times. remove the bottom front panel. You will see a black boot that comes down from the tub. Loosen the clamp on top of the boot. You should be able to pinch the boot and feel something hard inside the boot. Pull the boot down from the tub and put your fingers down inside the boot and pull up the coin collector. It may be full of junk, coins ect. Clean it and replace the boot and clamp. This should help you.
Jul 16, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
No spin cycle
Before you try changing the control board, try changing the brushes of your motor.
Jun 14, 2008 | Washing Machines
Washing Machines Logo
220 people viewed this question
Top Washing Machines Experts
