Question about Nikon D70 Digital Camera with 18-70mm Lens
Rear Colour LCD Screen Problems
If you look straight on at the rear LCD Screen on my D70 it looks totally white, but if you look at a 45 degree angle to it you can see SOME colour not much but can you buy a replacement LCD screen for it? or could you buy a D70s replacement rear or anything?
The camera works fine just i cant see the menus.
The 1 Year warranty ran out 3 years ago.
Thanks for reading
Rob:)
  • dax83 Aug 23, 2008
    There would be no point selling the camera as I would end up buy a cheaper one that isn't as good. Thank you for the information thought.
    Do you know where I could get the D70 Service Manual?
  • 24 Answers
If you intrested to sell the camera tell me how much u want otherwise lcd is available see www.omaxphoto.com.it mifht be something wrong with display back portion it has to be cheaked by an expert
Posted on Aug 22, 2008
If M is the midpoint of triangle ABC, ACB = 30degrees and BMA = 45 degrees, calculate the size of BAC in degrees.
Since M is the mid point of the triangle, the distance of M from A,B and C is equal which means AM = BM = CM.
Therefore, MAB = MBA. In triangle MAB, MAB=45 degrees.
sum of angles in a triangle = 180 deg. So, sum of angles MAB and MBA = 180 - BMA = 180 -45 = 135.
Since both MAB and MBA are equal , MAB = 135/2 = 67.5
In triangle AMC, MAC = MCA . Therefore MAC = 30/2 = 15 deg.
Therefore total BAC = MAC + MAB =82.5 deg.
May 19, 2017 | Homework
I need the rear suspension adjustment figures for wh statesman
From the Holden Service CD:
The toe-in specification is deliberately quoted as an angle because wherever possible toe-in should be measured in degrees. Refer below for the recommended wheel alignment settings. These settings are at curb weight, which is the vehicle
in a condition of full fluids, full fuel, no people or luggage.
Front Toe-in Degrees Total 0°10' ± 0°10'
Degrees Per Wheel 0°05' ± 0°5'
Camber - 0°30' ± 0°20'
Caster 7°45' ± 1°15'
Rear Toe : 0 ± 1mm (0°± 0?10mins)
Camber : -1°30mins to -2°30mins
Torque Settings : 65 ± 5Nm
Jun 29, 2016 | Cars & Trucks
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
How do i get my calculator to do the trig problem Tan45=1? It is telling me Tan45=1.61977, and i know that isn't right.
Angles may be measured in three angles:degree, radian and gradians (grads).
tan(45 deg)=1
tan(45 radians)=1.61977
If your problems require angles to be measured in degrees, make sure that the calculator's angle unit is set to degrees.
In RUN screen press [SHIFT][MENU] (SetUp) select the angle line and press function key under the tab Deg (should be F1).
Sep 17, 2013 | Casio FX-9860G Graphic Calculator
A rock climber throws a small first aid kit to another climber who is higher up the mountain. The initial velocity of the kit is 18 m/s at an angle of 74° above the horizontal. At the instant when the...
Depends on how long it has been travelling. If it is horizontal when it's been caught then ot must have reached zero velocity. No matter the angle gravity works at 1m/s/s. Do the math.
Sep 18, 2009 | NorStar Operational Software Category E...
Bmw 5 seies m reg the rear view mirror has been pulled off but the wires are still connected. how do i mend it.
If the small metal button is still attached to the window, the all you have to do is hold the base of the mirror on the window button at a 45 degree angle and then twist it straight to attach.
May 17, 2009 | 2001 BMW 5 Series
Lexmark T620 Fuser Error
922 fuser error can mean to things #1 the fuse in the low voltage could be blown. #2 the thermal fuse or the lamp are blown in the fuser. looking at the back of the printer the outer rear cover door remove it by opening to a 45 degree angle and lift it off. on the inner rear cover there are to flat head screws loosen these the will not come off the cover. at the top of this cover there is one tab on each side pull in on these and pull the rear covere off this will leave you looking at the fuser. there are to screws holding the fuser in loosen these they will not come off the fuser. from the center of the fuser tray pull straight back. on the front of this fuser you will see 2 white connectors one has a single row of connections this is the ac circuit with a multi tester check resistance from pin 1 to pin 3 if you get no reading then it is the fuser. try this you can find out for sure
May 04, 2009 | Lexmark T620 Laser Printer
Black, Red and yellow triangle in upper right corner of the scrn.
YOU HAVE A CONVERGENCE PROBLEM IC'S WILL NEED TO BE REPLACED. THE FACT THAT THE LINES DID NOT MOVE WHEN YOU TRIED TO ADJUST THEM CONFIRMS IT.
Jan 19, 2009 | Toshiba 57H81 57" Rear Projection...
Nikon d70 photo results
You might want to change the white balance or bracket your exposures
Here is a link to the photonet site that may give you some things to try: Photonet
Feb 23, 2008 | Nikon D70s Digital Camera
Nikon D70 Digital Camera with 18-70mm Lens Logo
108 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
