Question about Logitech Cordless Mouse
Mouse I have a rechargeable mouse just got new receiver as I lost the other one in Hawaii. Read the instructions and put in the address but didn't come up how do I get the receiver and the mouse to work tgogether? Thank you Marjorie Barton
  • marj38barton Aug 25, 2008
    where is the reset button on the receiver????
    It seems to be a sealed unit.Thank you
    I have a logitech mx revolution and there doesn't seem to be a reset button anywhere, I also have vista ultimate don't know if that is a problem that adds to it or not.My other logitech mouse works okay it is just the new receiver I had to order. I keep calling logitech but their phone is always busy.
    Thanks for trying to help
    Marjorie
    Problem Solver:
  • 8 Answers
You should press the reset button on the receiver for 5 seconds. Let it go and then immediately press the reset button on the mouse once. Hopefully this should get it going.
Rgds
Tony W
Posted on Aug 23, 2008
  • 1 more comment
  • Tony Woodward Aug 25, 2008
    Is your receiver a blue sort of half oval triangular shape. If it is there should be a black button in the center of it.
    Hi Marj
    If my previous info does not cure your problem (i.e, you have no reset button on receiver) try this.
    Rgds
    Tony W
    Hi again Marjorie.
    I have found instructions on the logitec website for your particular mouse.
    Perform the connect procedure for the MX Revolution as follows:
    • Make sure the mouse is turned off.
      Note: The on/off switch is located on the base of the mouse.
    • While keeping the left button pressed, turn the mouse on.
      Make sure the battery indicator does not turn on. If it does, start again.
    • Still while keeping the left button pressed, click the right button 5 times.
    • Release the left button.
    • Open the connect utility by clicking on start>all programs>logitec>mouse and keyboard>connect utility
    • Once you have launched connect utility, simply press ok.
    • NOTE: DO NOT FOLLOW THE ON SCREEN INDICATIONS
    • Your mouse should be re-connected within 2 seconds
    Hope this helps
    Rgds
    Tony W
GE Optical cordless mouse will not work. Have shut down computer, reconnected the USB to CPU (Receiver), pushed button on mouse. Red light blinks, but will not connect. What else can I do? Have lost...
I have a Logitech cordless mouse but had a problem recently. It fell on the ground and the batteries fell out. Put them back in, the mouse came back on but didn't work. Pushed the button on the mouse several times, no luck. The light at the receiver was always blinking whenever I pushed the button on the mouse, so I assumed that should work. After a few tries, I ended up pushing the button at the receiver and low and behold, the mouse was working again.
Have been using this mouse for years, had that problem only one.
Hope it helps.
D.
May 09, 2011 | GE Optical 98802 Mouse
When i use the wireless mouse,the cursor won't go with the mouse movements and is erratic.Could you please instruct me how to set up my mouse and keyboard correctly as i have not used this type of...
If the batteries in the mouse are rechargeable, recharge them. If they are not, replace them. Get your mouse closer to the receiver. Change the frequency channel they communicate trough using the Connect buttons on the receiver and the mouse.
Aug 14, 2010 | Computers & Internet
Keyboard working. Mouse not. New batteries, red
sometimes you have to reset the mouse with the keyboard out of the aera / check the connection to the pc if the keyboard can be read and the mouse can't then the mouse has lost its transmitter
Mar 01, 2010 | Logitech Cordless Desktop EX110
Targus wireless mouse amw05 does not work, I put in new batteries and pushed button on mouse and receiver. Still nothing. Using Windows XP
The reciever is poorly designed. The green and/or white wires are probably broken on the inside.(pins 2 and 3)
Nov 19, 2009 | Targus PAWM001U Mouse
Lost the mini receiver to my Logitech desktop MX3200 laser please help me out!!!
Not even Logitech could help you with a lost component without which the system won't operate unless you can directly wire the keyboard with the mouse wired (wait a minute, neither has wires, do they) to the desktop.
Here are your options:
1.New wired Keyboard and Mouse:
2.New duplicate of what you had, with careful shoppiing to make certain that the same channels are useful to your receiver (of which you will have one) while you have two KBs and Mice addressing one
receiver for dual control of one desktop which is exactly why one purchases a KBR.
3. Purchase, if available a new receiver from Logitech.
My choice of the above options is Door #2
Apr 21, 2009 | Logitech Wireless Access Duo Optical...
LX7 cordless optical mouse with dongle
Had the same problem. But before filling the logitech RMA from to get a replacement, I put new batteries into the mouse and the mouse worked again.
I am using rechargeable batteries, and I seems to me even if the green light on the bottom of the mouse is on, the driver warning for low battery does not come on. May be the volage drops to fast with a older set of batteries.
Try out new batteries. Hope this helps.
I am using the LX7 mouse for more than 2 years with lost of abuse (>10x drops from shoulder hight to hard office floor, sitting dongle in my pocket and dropping my backpack onto the floor with the dongle on the botton in the backpack).
Regards.
Oct 03, 2008 | Logitech LX7 Cordless Optical Mouse
"Cyber" brand wireless rechargable mouse
Okay i got the same problem i did everything press the big blue botton and the one on the bottom of mouse and still nothing....
ITS THE BATTERYS!!!! the ones that come with it are shiet i put some tranisonic ones into and it worked instantly the moment i put "good" ones in the red light came on instantly
Aug 23, 2008 | Computers & Internet
Flahsing Red Light
Now what you have to do is look for a reset button on your mouse and your wireless mouse signal receiver.
When the receiver and mouse both are on press the reset button on both of them one by one.
This should solve the problem.
Jul 16, 2008 | Logitech MX 700 Mouse
Mouse doesn't work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 03, 2007 | Micro Innovations KB985W Keyboard
Logitech Cordless Mouse Logo
98 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
