Question about Memorex MVD2042 DVD Player
Hook ups how do I hook it up to the tv and a video recorder??
    Sergeant:
    Novelist:
  • 166 Answers
Hook the Dvd player to the video recorder then hook the video recorder to the tv
Page 10 of the owners manual gives instructions to hook to your tv and that the same process to hook to a video recorder, just hook to the av inputs on the video recorder then hook the outputs from the video recorder to the tv.
Here;s a copy of your owners manual in pdf in case you need it
http://rapidshare.com/files/139274727/MVD2042OM.pdf
Posted on Aug 22, 2008
    Sergeant:
    Champion:
  • 317 Answers
Use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
2 Suggested Answers
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: JVC DCD Recorder hookup to digital TV
Yep, this recorder is NTSC analog. Sad, too - it was only manufactured in 2006 - they knew about the digital transition then. There is a possible workaround, but it depends on your TV - if your TV has a red, white AND (most importantly) yellow OUT/OUTPUT, then you can hook it to the AV IN on the back of the JVC and record from TV that way. Note: most TV's (even new ones) do not have the yellow video/monitor OUT, even if they have red and white audio OUT's.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Hooking A480 to record video from TV
The A480 is a camera, not a video recorder. You can play back videos on a TV, but you cannot record a video from a TV.
May 01, 2012 | Canon PowerShot A480 Digital Camera
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Mar 24, 2009 | Panasonic DMR-E30 DVD Recorder
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
-Tha Mp3 Doctor
Sep 03, 2008 | JVC DR-MV7 DVD Recorder/VCR
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Memorex MVD2042 DVD Player Logo
463 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
