Question about Broderbund PrintMaster Platinum 16
I recently got Print Master 17 but I can only download 1 of 5 CDs. Now I tried to configure my printer but only get A & B test sheets and the 'next' button isn't lit up. now what?
Ghnghngfhngb bv bvmhjfghdh
Posted on Aug 26, 2008
Why xerox phaser 6360dn is printing only pink
Anonymous, Have you tried to print the test print, is that Pink?
Have you tried too print the configuration sheet, is that Pink?
Have you tried to run purge sheets are they Pink?
If the answer is yes to all the above then has the printer been moves whilst still hot or warm, you could have mixed the colours.
If all the colours were mixed together then you would have a dark dirty Brown. Further investigation needed.
Good Luck.
Sep 05, 2014 | Xerox Phaser 6360 Laser Printer
How to print a Test Page Configuration sheet in minolta 350
To print a Configuration page, perform the following:
1. While in Copy mode, press the Utility button.
2. On the LCD press Printer Settings.
3. Press Check Job Settings. Configuration page will print at this time.
on Jun 16, 2010 | Office Equipment & Supplies
Error code E01 stands for?
Basis Steps For All Printer. ( Ink jet or Laser jet )
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 25, 2011 | HP 4050: HP 4050 laserjet printer , 8MB...
Printing is offset
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
􀁺 Ensure that the Inner Cover is closed.
􀁺 The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
2 Open the Printer Properties dialog box.
See “Opening the Printer Properties Dialog Box Directly from the Start Menu” on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment.
remember if my answer was of assistance please leave a positive rating and a testimonial.. THanks Good luck
Mar 28, 2010 | Canon Pixma iP3000 All-In-One InkJet...
I have re-installed my printer. It prints, but doesn't print anything what's going on?
I think you mean it sheet-feeds but does not print. If so, power off. If network connected, power off the print server. Power all back on after a minute. Depress power button on printer for 10 seconds.
If auto test page prints, problem is with printer configuration on your computer. Check the configuration carefully. Did you uninstall with the HP Scrubber utility before you did the re-install?
In If the test sheet feeds but does not print, use the HP printer utility, check ink levels, check cartridge "expiration", and clean heads several times. Test again.
Oct 21, 2009 | HP PSC 1610 All-In-One InkJet Printer
Test sheets will print, but nothng I try to print works
Remove the 1610 printer using add remove programs adn the reload it. Sound like software rather than hardware
Apr 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
network cable,Thanks
Feb 23, 2008 | HP LaserJet 2430dtn Printer
Keeps printing test sheet
I just had the same problem after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Jan 09, 2008 | HP PSC 1350 All-In-One Thermal Printer
Computers & Internet Logo
59 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
