Question about Akai LCT2715 27 in. LCD Television
Power Board No Power
The TV dosen't turn on, we changed the fuse, but still do not work
  • Anonymous Aug 24, 2008
    The front light of the TV flashes rapidly but TV wont turn on.
I just fixed one off these units for ten dollars, this is a common problem with this tv. power supply is built very cheap. if you have any experience with soldering you can fix the power supply. if you remove the power supply then remove the heat sinks you will probly see on the end where the ac power is connected a bunch of capacitors if any of the tops are bulged up or show signs of leakage out the top they are probly bad. i changed 10 and fixed my problem. hope this helps cause you wont find a new power supply except one on ebay right now.
Posted on Aug 24, 2008
Phillips 39" tv problem
a power surge can do alot of damage but does your model have a fused plug? as would check this. if you have changed the power board for a know working one then the main av board has gone this is the board that tells the power board to turn on.
Jul 15, 2017 | Televison & Video
Seiki LCD TV no activity at all when power button pressed. Would replacing the main board fix this? Can that be done by an average person without soldering?
Hi Steve,
Before changing the main board for a dead TV there are quite a few things to be checked. First of all the main cord, then the fuse on the power board and then the power board. In your case please check the fuse on the power board and replace it with the same rating. If the TV starts working, enjoy watching and if the fuse blows again, consult some TV Tech.
Jun 30, 2015 | Seiki Televison & Video
I have left my viera panasonic plasma tv model TH-P50X10A, unpluged for two months I tried to power it up the green light flickers for a moment then slowly flashes red and the tv dosen't work.?
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 19, 2012 | Televison & Video
I have a panasonic plasma hdtv. When I turn it on--usually--the red light flashes. It flashes continually--not in a sequence. I can keep pusing the power button and sometimes the tv will power on--but...
Must have to take the tv aparts,check the tv power supply board carefully.That the board where the tv a/c power cord plug into it.Look for dying and leakages capacitors components parts.These dying and leakages capacitors parts are causes this problems 90-95% of the times.These dying and leakages capacitors components parts are alway bulges up and or puffing up onto it tops.It dosen't supose to have a flat tops as those are good capacitors components parts that are alway have flats and even cyclinder head tops.If u have all the tools and know basic electronic and also u can do basic soldering work too than u must have to changes all these dying and leakages capacitors components parts that are bulges ups or puffing ups on to it cyclinders tops,will solved this tv problems LED power liight inconsistance staying on power LED light indicaton flashes.If u can't do soldering works on an a electronic board components levels works.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Dec 02, 2011 | Panasonic Televison & Video
Apex ld1919 power light just blinks instead of going on
Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting itself back to the tv factory setting.The tv now should be working again.If the tv dosen't and the tv still having the same problems.Mean ur tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 28, 2011 | Apex Digital LD1919 19 in. LCD TV
We had an electrical storm strike close to our house and now our prima c2012 will not turn on.. it will not turn on with the remote or by manually pressing the on/off button.. is there anything that can be...
you can open the back of the tv and see if it blew the fuse but watch out for the flyback anoid it still holds power if you don't know what that is it the thick red wire that plugs into yhe tube so DON'T UNPLUG IT FROM THE TUBE you will get a big charge and the fuse should be near the flyback and if it still dosen't work the the output IC is probley fried.
Sep 12, 2011 | Prima C2012 TV
Lighting was bad in my area and my tv was plugged inns surge protector the tv turned on bit the power light blinks with the opc light my dish won't how up on the tv what do u think is wrong??? I turn...
The tv have a problems with the board that called the tv main Tuner signal board.That the board where the tv incomming broadcasting signal cable plug into it.This tv it still useable.I have one too a 46".Try tv unplug,replug it back like about an hour this problems will solved for a while evenually will return though.Every times POWER and OPC LED lights flashes,just push the tv power button ON again on the remote and have to wait,sometimes tv it will lite up and work right away.Sometimes it will have POWER and OPC LED lights flashes again.Just have to push the remote power button ON again and wait a while again eventually tv it will lite up and work.Have to this like 3 or 4 times power ON button pushes somtimes,tv will eventually work though.I know i do this manytimes before my tv have this problems off/on 3 1/2 years.But finally u will have to replace the tv main Tuner signal board sooner or later though this solution dosen't work for the rest of the tv life.U can do some basic mechnical works like take things aparts and putting back together again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Turner signal board for the replacement.
Sep 02, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Nov 01, 2009 | Televison & Video
Plasma tv on the fritz
no problem dont be afraid to take the back off the tv check all fuses on all boards especialy the board on right side wich is the video process board controlls all video function if its not fuses check board i had same problem replaced mine so far so good good luck mark shalme
Mar 27, 2009 | Luce PDTV-4203A 42 in. Plasma Television
Akai LCT2715 27 in. LCD Television Logo
91 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
