Question about HP Deskjet 3845 InkJet Printer
Squeaky HP Deskjet 5440
I have an HP Deskjet 5440 that squeaks when printing. Is there anything I can do to fix this? I work at an elementary school and it is extremely disruptive. Thanks!
  • sdonner Aug 22, 2008
    My HP Deskjet 5440 squeaks when printing. It squeaks when printing starts and the printer cartridge rolls across the carriage and as the paper is rolled out.
    I was hoping there was something I could do myself, but I guess I will have to take it in.  Probably more cost effective to get a new printer.
    Sergeant:
    Champion:
  • 298 Answers
Solution
  1. Turn the printer on.
    • For the 800, 900, 3820, 5500, and 6000 series, open the top cover of the printer. Verify that the carriage moves to the center of the printer. If the carriage does not move to the center, proceed to step 2.
    • For the 5100, 5600, and 5800 series printers, open the top cover of the printer. Verify that the service station (the piece below the cartridges) lowers, allowing access to the cartridges. If the service station does not lower, proceed to step 2.
  2. Unplug the power cable from the back of the printer.
  3. If the carriage moved to the center, or if the service station lowered, remove the cartridges. Check inside the printer for any broken parts. If the carriage did not move to the center, try to manually slide the carriage to the center. If the carriage is locked either in the left or right position, proceed to step 5.
  4. Close the top cover of the printer.
  5. If the printer is a HP Deskjet 900 series printer, refer to the HP support document Removing the Cartridges if the Printer will not Turn On or the Carriage is Locked (bpd50074) . This document will provide information for unlocking the carriage from the right side of the printer. If the issue is on another model of printer, proceed to step 6.
  6. Remove the rear access door, or the automatic two-sided printing accessory, and check for any paper jams or paper obstructions. Remove any obstructions.
  7. Check to make certain the carriage is on the right side of the printer. Rotate the rear paper guide rollers upwards five times, then downwards four times. If the rollers will not move, open the top cover and slide the carriage to the right (if it is not already there and if carriage can move). Try to roll the rollers again while pushing the clutch in. If the rollers do not move, continue on to the next step.
  8. Replace the rear access door accessory, or the automatic two-sided printing accessory. Close the top cover.
  9. Plug the power cable back in.
  10. Turn the printer on, and replace the cartridges if possible. If the carriage moves, but there is still a grinding noise, there may be a paper feed issue. If the carriage will not move, then it is a carriage stall issue.
  11. After installing the cartridge, if the printer has a solid power light, perform a self-test on the printer.
If you have completed all of the steps listed above and are still experiencing a problem, service the product.
Posted on Aug 22, 2008
  • 435 Answers
The best solution for this problem is to get the printer serviced by technician.
Thanks
    Master:
  • 521 Answers
Just get your printer serviced to free up the carriage rod and gears.your printer is absolutely fine and a normal servicing will 100% solve your problem.have a nice day .thanks.please do rate the solution.
regards.
fixya expert team.
    Genius:
  • 2,035 Answers
  • 157 Answers
Hello sir
  • John Smith
    John Smith Aug 22, 2008
    u may wanna clean bridge where the cartridges run back and forth when printing
    Maybe get some oil (the type they use for doors) and put some on.
    Hope i explained it well
    Cheers
    Jigsaw
    Fixya Team
My HP Deskjet 5440 won't print. The "ON" Button is
hi there!
just push the power button to restart its print job, if that dont work, ive posted the link for that printer here, check out the manuals and troubleshooting steps too, they're all for free. you can also contact 800-HP invent or 800-474-6836.
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=445441
Apr 07, 2011 | HP Deskjet 5440 InkJet Photo Printer
Setup with a netgear print server
Be sure you have it setup correctly and the IP address is correct. Also you may want to check with Netgear on whether or not that model is compatible with Bi-Directional printers.
Jan 13, 2010 | HP Deskjet 5440 InkJet Photo Printer
Cancel print on a HP Deskjet 5440
on the bottom right side of your computer screen you will find a icon of a printer.click on it .a screen with the printer driver will apper and the job you printed will be listed on that screen.right click on it and then click "cancel"you can leave the printer turned of as it will take a few minutes to do this.during this time the printer will keep pushing out paper if it is not turned off.
Nov 10, 2008 | HP Deskjet 5440 InkJet Photo Printer
Printer
Windows comes with drivers for many HP printers.
You can try to install your HP deskjet 5440 by going to (depending on operating system) "Start", "Printers and Faxes", "Add Printer". Select a local port. Select "HP" and Model "HP Deskjet 5440".
If 5440 is not in your list, or if you want the latest driver, you can download the driver for your specific operating system here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445441&lc=en&cc=us&dlc=en&lang=en&cc=us
Aug 02, 2008 | HP Deskjet 5440 InkJet Photo Printer
HP 5440 TOP MARGIN ERROR
When you fixed the gear it probably adjusted the timing. You will have to move the gears around until you can find the home position.
Jun 28, 2008 | HP Deskjet 5440 InkJet Photo Printer
HP Deskjet 3845 InkJet Printer Logo
309 people viewed this question
Seeker5211
Seeker5211
