Question about Sharp AR-M207 All-In-One Laser Printer
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
  • bullo2008 Aug 22, 2008
    Ive solved it by installing the XP drivers on the PC
  • Anonymous Mar 15, 2014
    Copy and fax work. Was printing fine through network. Now it's giving error. Tried to hook it directly to computer. It is communicating with computer says processing print data but does nothing I've done everything I can think of . Any ideas would be greatly appreciated.
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Posted on Dec 05, 2008
  • realkyu Sep 29, 2010
    Good advice. Bad link.
In my case, I installed a driver with the PCL at the of the driver name and it now works fine now. :D
Posted on Dec 18, 2009
    New Friend:
On win 8 64bits You can use the driver of SHARP AR-208d PCL6 for install properly the Sharp AR-M236 printer.
1/ install the SHARP AR m_236 on your computer
2/ Change the property and the pilote with SHARP AR-208d
3/ It works
No thanks to sharp, thanks to me
Posted on Jan 22, 2014
    Sergeant:
    Champion:
  • 317 Answers
It could be that windows 2000 cant handle the data that is being transmitted to it (too much to interpret and transmit so it gets backlogged and corrupt) through your network, I would suggest installing either a queing software on the computer so that it feeds the data one piece at a timne, or upgrading the computer to XP or windows Server 2003/2007.
Posted on Aug 22, 2008
What does "100 %" stacked mean?
it means that the printing order for the memory for the printer is full
go to control panel , go to printers and hardware , click on printer right click and it will show a section see what is printing
high light each line and delete that takes away the priority of the stack until there is nothing left to print and the printer should again print at the next selection you make
How the program works is this
there is a small memory in the printer and a large one in the pc
when you have data that is to be printed, the pc sends the data until the printer memory is full at which stage the printer starts to print. new data is sent as memory space becomes available until the document is printed
when different data is requested to be printed or there is a hiccup in the process the pc looses the priority in the print list ( page number or new document)and so backs up that memory and becomes blocked
by going into the pc in the printer hard ware and deleting the printing waiting to be processed your are unblocking the process and allowing the pc to again move data to be printed
Nov 08, 2015 | Brother Office Equipment & Supplies
Error : Printing data is inaccurate, printing processing is stopped. For my Printer AR-M160
Go to http://support.sharp.net.au/drivers/ then go to photocopieres, from there scroll down through the models and download the driver for ar 163 and install it and try to print this will resolve your problem , if any quries feel free to contact , rate this and vote for this after getting your problem resolved
May 25, 2011 | Sharp AR-164 Copier
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This...
some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
May 09, 2011 | Lexmark X7350 All-In-One InkJet Printer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
I was having a printing on animal care (book) It had 164 pages so I stopped the printing now it starts printing the book all over. How do I cancel this book? Canon iP1800 series
itz problem/error of print pooler..
often happens due to data resent viz. reprint/overload/document mismatch/page error and so on..
itz very common..don't panic..!!..
snatch out all the paper(s) in the tray (but not which is printing)..set all the document in the print pool to delete..just turn off the printer..restart the system..
hope it'll b fine..
best to seek guidance of ur system admin/vendor....
Nov 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Samsung clp 510
usually happens when the NIC card goes bad, may need to replace.
first try resetting the printer, look in your manual
Aug 25, 2008 | Samsung CLP-510 Laser Printer
HP 4350 ERROR MESSAGE: 49.2F90
he printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Sharp AR-M207 All-In-One Laser Printer Logo
12,103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
