Question about Whirlpool Duet GHW9150P Front Load Washer
F28 Erorr message F28... F 20 What does that mean...
  • bigblk_trk94 Dec 07, 2008
    f-28 then stops ???
  • 876 Answers
F20 usually means that the drain is plugged. It could just be twisted or compressed as well.You can check the washer drain by pulling it out from the wall and unclamping the drain hose (black about 2"diameter) and check for a plug. You can also sometimes pull it out of the standpipe or wall drain if you cant clear from the washer end. Be sure to turn off the washer and unplug it before you do htis, and have some old towels handy and a container available. If the washer drain is not plugged, it could be that your household drains are running slowly. Check your sinks, toilets, etc and in particular run a lot of water through your disposal if you have one and run it.
After you have cleaned the washer drain adn reattached the hose, let it sit unplugged for several minutes (Don;t get the plug wet!) Then replug it and turn it on and see if the code has disappeared. If it has not you will need to go to the following site
http://www.whirlpool.com/custserv/index.jsp
And look for the appropriate sevice for your machine.
Thank you for using Fix YA and good luck to you.
Posted on Aug 22, 2008
  • 639 Answers
Edethc
sorry abut my answer having unrelated matters in it!
They were in clip board on my computer and they came to you by mistake!!
You need service for this problem!
and these guys are good and nation wide!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
ngafm2
Posted on Aug 26, 2008
  • Neil
    Neil Aug 30, 2008
    WHATS ALL THIS YOU SENT ME??????????????
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style
    Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0;
    mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt
    0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New
    Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400;
    mso-bidi-language:#0400;} You need service!
  • Neil
    Neil Aug 30, 2008
    Try this company!
    And download the user Manuel at whirlpool .com
    Call a local appliance store that does repairs!
    And you talk to them on a one to one personal level and they may give you an answer before service shows up !
    1800-905-9505
    Neil
Technical problem with washer read out F28 - what does that mean?
F28 means there is a communication error on the control board.
Check for water ingress and bad connections.
Dec 15, 2017 | Washing Machines
I have an F28 error what is wrong
As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore H2 PLUS reads F--28 code what does this mean?
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Here's the online repair manual for your
Whirlpool Duet Sport, but its identical to your HE2.
Give it time to download.
On page# 4-20 it shows how to access your MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Feb 13, 2011 | Kenmore HE2 Plus Front Load Washer
Code f28
Hi, the error code F28 means one or both of these parts are bad.
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28. If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
You can download the online repair manual in the below link
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F28 CODE
Whirlpool Duet
Jun 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f28 error mean
Your camera does not support the aperture range, maybe.
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HI WHAT IS CODE 62 AS AN ERORR MESSAGE
Code 62 error message on this washer means that the "drain pump" current exceeds what it should be. Either the pump is faulty or (more expensive) the motor controller is faulty. Pump about $50.00, controller $300. Best of luck. 2TRP
Feb 22, 2009 | Fisher and Paykel Washing Machines
F28 error
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
143 people viewed this question
Dan Webster
Dan Webster
Sal De
