Question about Lands Phones
Speed dial add numbers - Lands Phones
Hold the speed dial number down, then dial.
Posted on Oct 13, 2008
Speed dial option in Karbonn K451+ Gold champ
Hi Nilesh, the user's manual says, quote: "Speed dial: If you already set the speed dial numbers, then you can long press number key 2 to 9 to dial set numbers out under the standby mode.Long pressing number key 1 is to dial to voice mailbox if you already set the mailbox number." So it looks like you need to add the speed dial option in your chosen contacts details, first. Then follow the quote above. Good luck!
Dec 19, 2014 | Cell Phones
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
I'm having problems with a Samsung KPDCS-12B LCD phone I've recently been given, I need to add myself to group 501 to take calls for my department (Plumbing) but my phone (Extension 250) is...
Hi you need to do this in 2 parts - firstly to add yourself to group 501 follow the step-by-step instructions which are on the video I have posted. Then follow this to add a mobile number to the directory;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
dial 705
I.e. once in 705
Type in speed number, the cursor will tab over to speed dial slot.
Enter 9 followed by the phone number.
Press 12th button down,
Enter name,
Press 12th button. (You will be back at the speed dial.)
Press tab, then enter the next speed dial slot you wish to program.
NB-
( 705 - Speed dial 12th Button down to toggle between)
( 706 - Speed Name the 2 MMC
Jun 08, 2011 | Samsung DCS 12 Corded Phone
How to enter a "speed dial number / name
Step 1Tap Start, and then tap Contacts.
Step 2Scroll to the contact for which you want to set up a speed dial number and press ENTER.
Step 3If you have entered more than one phone number for the contact, scroll to the phone number for which you want to add a speed dial number.
Step 4Tap Menu, and then tap Add to Speed Dial.
Step 5In the Location field, scroll up or down to select a keypad number. (Optional: If you skip this step, the device will assign a keypad number automatically.)
Step 6Tap OK.
Good luck.
Aug 31, 2010 | Panasonic KX TC1743B Cordless Phone
How would I set up on my fax machine to send one report to multiple numbers?
You need to add numbers first in all Speed Dial & then add those speed dials in Group dials.So that you can send that group to all locations at 1 time.
If you think it was helpfull rate me..
Aug 04, 2010 | Office Equipment & Supplies
How do I load contacts into speed dial and get them to work?Went by book ,pg. 14.When I try to speed dial it says not on list.
Go into you contact list and highlight the contact you want to add to you speed dial. Press the menu key and scroll down to the "add to speed dial" option and select it. The phone wil then ask you to select which number you would like to assigin that contact to. Once you have selected the number you want press the red end key to exit out and test it by holding the number you assigned that contact to down till it calls that person.
Feb 03, 2010 | Motorola Mobility Karma QA1 Cell Phone
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
Programming speed dial numbers
just hit the phone button type in the number a button will highlight that says add to speed dial
Dec 01, 2008 | 2007 Toyota Prius
Speed dial
Scroll to the name you want to put in speed dial. OPTIONS tab then DETAILS....then scroll down to ADD TO SPEED DIAL then it will prompt you Yes or No? click on YES..then pick a position and SELECT
Dec 05, 2007 | Cell Phones
Lands Phones Logo
674 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
