Question about JVC Mobile Mini Note PC MP-XP5230 PC Notebook
Run out of disc space
Have less than 3% disc space available-
  • travis79 Jan 20, 2009
    .97 g left i need more free
  • 282 Answers
Try running ccleaner from
Posted on Aug 22, 2008
Drive C shows low disc space but is only half full
This could be caused by a virus, or you could simply have a small HDD with a newer version of your OS. Certainly I recommend running a full scan with the free version of Ad-Aware Anti-Virus from Ad Aware Free Antivirus and Antispyware by Lavasoft Protection from... to start with. Also, if you have a smaller hard drive, something around 40GB or less, newer versions of the Windows OS will not consider the percentage of the drive's storage space in use, but only the raw amount of free space available on said drive.
Another possibility involves the paging file and its size, something which would be a concern on any modern OS. If your paging file, or virtual memory allocation, is too large, you can receive warnings about low disk space because even when it is not in use that storage space is counted as "in use" by your OS.
Finally, in general these types of problems can result from not performing routine maintenance on your HDD and its partition(s) and file system(s). Running a file-system integrity scan and a thorough defragmentation operation on your drive is a good idea just on principle alone.
Apr 29, 2014 | Computers & Internet
How to reformat j3
Restore the OS. Space my be corrupted or used up by old updates and cluttered files.
Mar 07, 2014 | Cowon J3 (16 GB) Digital Media Player
I have a acer aspire one and this pop-up keeps coming up saying 'out of virtual memory' - i dont know what to do. Also every hour or so my theme changes to classic (i have Windows XP) for about 5-10...
Virtual memory is the space the laptop uses on the hard drive to write to and read from. It usually is caused by running too many applications at once, thereby putting a greater demand on the free disc space you have,
Firstly, you need to check how much free disc space you have. Less than say 1 GB will flag up the issue ( depending how much virtual memory the computer is allocating). You need to remove some data from the hard drive and back it up to free some disc space
Then consider upgrading your ram to help you run more programmes at once if needed
Finally, consider getting an external usb drive to store data on, or upgrade your hard drive
Jan 14, 2011 | Acer Computers & Internet
Dell 531 Multiple problems: - Running slower and slower by the day - Keeps trying to do automatic file backups, but then shows an error stating that my backup disk space is low
I think you need to increase the Physical Memory of your computer... If the physical memory is less, system goes slow...
You can increase your available physical memory by either adding more memory chips or by deleting existing software or files. Pls follow this step: Go to RUN, type WINMSD.EXE You can able to see the available physical memory. If the memory is very less then you need to increase the space as I mentioned above. Pls let me know if this doesn't work.
Dec 12, 2010 | Dell Inspiron 531s Desktop Computer
Playlist exceeds disk space will not allow to create cd
Delete tracks from the playlist to bring the total time to less than the maximum available on the CD. If you're trying to write a redbook CD this will be just under 80mins, less if you're using higher sample rates and CD24 discs.
Nov 30, 2010 | Alesis MasterLink ML-9600
I am trying to backup using winzip 11.2 version. If I use dvd+r's it backs up 4.37 GB but if I use dvd+rw's it is much less.
Yes. Because the space available on rewritable discs will be less than the space available on write once discs.
Dec 28, 2009 | WinZip 11 for PC
Running windows xp home addition. tried d fragging pop up said i needed to run chkdsk /f. tried that and it poped up for less than a second and went away. still cannot run defrag pgm
reboot into safe mode. You can kill the power to the PC without shutting down. When you turn it back on it will ask you a few boot option, select safe mode, then try the defrag.
Dec 02, 2009 | Computers & Internet
My printer is printing slowly
Print speed can be affected by three important factors:
Available computer RAM
Available computer hard drive space
The HP All-in-One product paper sensor
Follow the steps below the ensure the computer is operating properly.
Step one: Verifying the amount of RAM
Verify the amount of RAM installed in the computer.
Determine the amount of memory currently in use by background programs or processes.
Programs/processes will run in the background even when no applications are running. Most of these programs/processes will be indicated by an icon in the lower right corner next to the time.
Less memory available for applications will result is slower processing time and consequently, printing speed.
To determine processes running in Windows 2000/XP , do the following:
Press Ctrl , Alt , and Delete simultaneously and then release.
From the Windows Security box, select Task Manager.
Click the Processes tab to view all running processes.
Click the Performance tab to view the total and available amount of memory.
To determine processes running in Windows 98 , do the following:
Open the Device Manager .
Click the Performance tab.
The available system resources will display as a percentage.
Turn off unnecessary background processes.
This will free up system resources and increase printing speed.
To turn off processes in Windows 98/ME/XP , do the following:
Click Start , Run , and type msconfig.
From the System Configuration Utility, click the Startup tab.
Determine what processes are unnecessary and remove the checkmark those items.
Step two: Verifying the amount of hard drive space
Follow the steps below to determine the amount of hard drive space on the main drive.
Open My Computer , right-click the C drive, and then click Properties .
This will display a chart along with the total hard drive space, used space, and available space.
Verify that there is at least 2-3 GB of hard drive space available.
The computer will require at least this amount to process printing data for simple text files, more for image files. The lower the amount of available hard drive space, will greater the time to process print data.
Step three: Ensuring the paper sensor is clean and not damaged
The all-in-one product paper sensor plays an important role in determining the print speed.
Printing a self-test or demo page will ensure that the paper sensor is in proper working condition. If the page completes in less than 40 seconds, the sensor is working correctly.
Even if the sensor is working correctly, the printer driver might need to have the paper sensor turned off. To turn off the sensor, follow the steps below:
Open the Printer folder, right-click the printer and click Printing Preferences or Properties.
From the Properties box, click thePaper/Quality or Features tab.
Under the Paper Type section, open the menu and select Plain Paper instead of Automatic.
This will disable the paper sensor and increase the print speed
Nov 10, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to resolve low c drive space
Try restarting your computer. If you don't restart every so often, the cache memory in your computer, which holds temporary files, can run out of space. You can also go into your system tools under accessories in the start menu and use the disk cleanup to get rid of unnecessary and temporary files, or defragment your drive to rearrange files so the computer maximizes available space.
Sep 07, 2009 | Neoware Systems e140 Thin Client - Thin...
Out of hard disk space
try to delete all temp file and reinstall your driver software disk may be your software is corrupted bcoz of that you geeting this error. bye
Sep 17, 2006 | Konica Minolta Dimage Scan Dual IV Film...
JVC Mobile Mini Note PC MP-XP5230 PC Notebook Logo
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tre Elkins
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
