Zoom
Hey bello205,
This camera does not allow the user to actually turn off the optical zoom, but does allow the user to shut off the digital zoom. If you are talking about the digital zoom make sure it is turned on in through the menu system. As far as the optical zoom goes make sure you are not in playback mode. If this doesn't work you can try having the camera reset to the original settings every time you shut off the camera by choosing this option under the setup menu in playback mode. If none of this works have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
Same problem... frozen in max zoom position, nothing doing.
Solution maybe a hard reset but could not find any instruction how to///
The same occured on my camera just out of the blue. When turned on the camera simply zooms to full zoomed in and none of the buttons do work. Only the mode dial button on top and the on/off switch still work.
I also have no clue how to force a reset without use of the menu.
Same problem.. Any solutions?
basicly the same it will turn on the button on the top to change between modes will work and so will the on/off switch but nothing els will??
the setup button wont work?? so is there no way of reseting the camera without that no way of reverting it to factory settings? i dont care if i loose the picures on it
