Question about NetGear WGR614 Wireless Router
Cant connect to network
I want to add my wireless router to my local area connection but idont know how to connect to the modem
  • Anonymous Aug 24, 2008
    need to install without disc
    Novelist:
  • 210 Answers
You want to add a <insert brand> router to... your PC's ethernet port? If so, you just need a straight-through ethernet cable with CAT5 connectors. One end into the LAN port of the router, and the other end into the ethernet port of your PC. Done!
Now... there is a modem as well? Usually you'd have the modem (DSL, cable, whatever) plugged into the router's WAN port. The router then can share it out to all the LAN ports (of which your PC will be one of) and to any wireless clients via it's radio antenna.
So that answers that question, but if you get that done and can't configure everything, ask another seperate question please!
Posted on Aug 24, 2008
How do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
What is theam.if we apply theam the wole appreance will change or only on desktop
How Can One Cable Modem Work With Two Wireless Routers? By Terry Stockdale Leave a Comment In How to Fry a Wireless Router or Two, I wrote about my brother's experience frying a pair of wireless modems in a lightning storm. Last week, I talked about what had happened, why it happened, and what he could do to prevent the problem in the future (this was the third set of routers, plus he lost a computer motherboard in that storm).
This week, we'll look at his network layout, and why he could not get the network to set up properly.
To summarize the situation, he has an office an a shop, with computers on his network in both locations. Some connect via wired connections (Ethernet), while others use wireless connections. His Internet cable comes into the office first.
In the past, he first used Linksys wireless routers. Then DLinks. This time, he chose Belkin wireless routers.
The incoming cable (standard cable-company RG6 coaxial cable) connects to the cable modem.
Then, the cable modem connects to the WAN (wide area network "Internet") connection on the router.
The local wired ports on the router provide connections for two wired computers. Notebooks connect via wireless connections. Finally, one wired connection on the router is used to connect an Ethernet cable that runs 250 feed to the office from the shop.
That cable was the lightning problem, as it runs outside in a conduit just a little bit underground. Effectively, he's got a 250 foot antenna looking for the electromagnetic pulse from a lightning strike. Most of us don't worry about that because our equipment is so well grounded in the house, plus the Ethernet cables we use are much shorter lines. Even if we have underground cable company lines running from their switch boxes to our houses, those lines are usually only exposed about 40 to 50 feet before they enter the dwellings.
Back to the situation. When he hooked up his replacement routers, the router at the shop immediately worked. Not so, on the router in the office. The Ethernet light and the Activity light just poounded away, blinking and blinking rapidly. But, nothing connecting to the router could get to the Internet.
If they connected a computer directly to the Ethernet cable in the office, without running it into the router first, it worked just fine. But, with the router in place, it didn't work.
The problem was the way he connected the two routers. The problem is that there is no Out Of The Box connection that will work reliably. At least one thing, usually two, has/have to be tweaked one way or another.
As one might guess, the easiest way to connect would be to connect one router's WAN connector to the cable modem, using Ethernet cable, and then use Ethernet cable to connect one of the Local Area Network (LAN) connectors on that router ot the WAN router on the other computer.
There is a problem with this setup, but it's easily solved. First, if you're using identical wireless routers, as he was, the wireless routers are both trying to use the same IP Address range and subnet mask for their local area networks.
That works fine for the first router, which is connected to cable modem. On the cable modem side, it gets an IP address on the Internet Service Provider's network - often an actual Internet address and not just a private network address. On the local area network, it assigns the IP address range specified in its setup menu. This often varies by manufacturer. In the case of Linksys, this is 192.168.1.x. In the case of the Belkin routers he bought, it was 192.168.2.x.
The problem occurs at the second router. On it's WAN side, it sees a 192.168.2.x network - but it's default setting tells it to give 192.168.2.x addresses on it's local area network side, too. In other words - it's confused. It doesn't know where to find the Internet because both networks are assigned the same addresses.
The solution was to disconnect the second router's WAN/Internet cable, connect to it via a wired computer, and tell the second router to use a different IP address range. We chose 192.168.3.x.
We hooked up the Ethernet cable to the Internet/WAN side of the router again. The router started working fine, normal light blinks for activity, no more confusion. The computers could get to the Internet just fine.
Problem solved.
That solved the Internet connection problem. However, no computers in the office would be able to share files or printers with the shop, nor would computers in the shop be able to share with the office. That was both acceptable and intended, in this case.
It could be done; however, that would require a different configuration on the routers and connections.
Jan 05, 2011 | Computers & Internet
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    Wanting to make my laptop wireless connection
    Hello.
    Connect the MODEM (device you received from your Internet Serivce Provider that gets the Internet signal) to the router via the WAN port. WAN stands for Wide Area Network and this gets you out to the Modem and then to the Internet.
    Ports 1 and higher are for computers and network printers that you can directly connect to your LAN - Local Area Network.
    To secure your connection, you will need to configure your router and you will need to connect your laptop to the router (either wireless or via one of the numbered ports on the back of the router), open a web browser and enter the IP address of the router.
    Since you did not put the model of the router, I cannot give you specifics on how to secure the connection. You can go to the D-Link web site, find your router, download the manual and it will walk you thru the settings.
    Basically, you will be entering a WEP key (a set of letters and numbers that you know) to allow only wireless computers that have this key.
    Apr 30, 2010 | D-Link DI 514 Wireless Router (DI-514)
    Cant get into 192.168.1.1 to fix problem
    Do you have cable or DSL internet service? On a DSL setup the router is at 192.168.2.1 . At the run command, ipconfig/all will give all the current settings of your network connection. The line with default gateway is your router address.
    Check the status lights on your router and modem as well as the network connection on your computer. You may want to try connecting to the modem itself with a wired connection and then reconnect the router and see if you can connect with a wired connection from the computer to the router.
    If your network works normally with a wired connection, use the device manager to check your wireless connection. Also go through the router setup to check that no settings have been changed.
    If you have missing lights on either the modem or the router, check the cables (replace them if you can) and transformers. A call for service from your ISP may be needed if the modem isn't connecting. (At least once, my DSL network went down after a lightning strike damaged the signal filter where the DSL split from the phone line.)
    I hope this helps.
    (I have an older router that does not give a local area connection if it loses the WAN from the modem.)
    Nov 02, 2009 | Linksys Wireless-G WRT54G Router
    How do I remove linksys broadband WRT54GS Wireless-G router from my pc. and revert to just my Motorola, SB5101 surfboard cable modem. Tried simply removing the router and pluging the modem back in, but no...
    Hi intriguedkiw;
    Yes this is fairly simple. Open up your network connections and delete the icon for the local area connection to the Linksys router, and click on Add new connection to create a new connection to the Cable modem. The add wizard will walk you through connecting to the modem, just fill out the questions correctly, and you should be good to go.
    Good Luck,
    Mark
    Please dont' forget to leave a rating.
    Feb 19, 2009 | Linksys Wireless-G Broadband Router
    My computer cant find my router
    1. Make sure your network cable from the modem to the router is good and connected to the uplink port
    2. If connecting directly try other port
    3. Check local area connection properties
    4. Double click "local area connection"
    5. On the middle box find and highlight "Internet Protocol ( TCP/IP) and click "Properties" button
    6. Make sure "Obtain an IP Address automatically" and "Obtain DNS server address automatically" are the only ones checked and click "ok" button
    7. Make sure "ethernet card" is NOT disabled
    8. Update ethernet card driver if necessary.
    Wireless:
    1. Turn wireless switch on
    2. Check wireless connection properties and that Internet Protocol TCP/IP configuration is similar to the above
    3. On wireless properties select "Wireless Network" tab and Add your SSID (wireless network name) if not there and if there Move "Up"
    4. Update wireless card driver
    Router:
    1. Double check to see that "Automatic Configuration" DHCP is selected
    2. Double check to see if "DHCP"server is enabled
    3. Check wireless network mode and select correct mode
    4. Check wireless channels and adjust as necessary
    Jan 18, 2009 | Belkin (F5D7230-4) Router (587009)
    I cant connect my wireless laptop tp my comp.
    Let me know the settings of your Router if needed IP address?
    Yes - add your IP address into Network Connection.
    No - obtained the setting in your Network Connection.
    How to Add or Obtained the setting s of your IP address:
    - goto Control Panel
    - Double Click Network Connection
    - Rigth Click then Properties the Local Area Connection
    - Select Internet Protocol (TCP/IP) and select Properties
    - Under General Tab they have choices to add or obtained settings.
    Sep 20, 2008 | Linksys Wireless-G WRT54G Router
    D-link di514
    Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
    Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
    Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
    Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
    DI 524 Connection Problem
    Try the DSL modem directly connected to the PC.No D-Link Router (powered off and disconnected). Verify that the PC couldsurf/browse/connect to the Internet. Go to Start, Control Panel, Network Connections, right click Local Area Connection, Properties, scroll down to/highlight Internet Protocol (TCP/IP), Properties button. Get the IP Add, Subnet Mask,Default Gateway and DNS assigned to the PC (write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
    Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router. Go again to Start, Control Panel, Network Connections, right click Local AreaConnection, Properties, scroll down to/highlight Internet Protocol(TCP/IP), Properties button. Tick "Use the following IP address". Enter this IP Add 192.168.0.10, Subnet Mask 255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what you have written down earlier). This willbe your LAN IP settings. OK, close, save or whatever is applicable.
    Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Use the IP numbers previously assigned to PC that you have writtendown as the router's WAN/Internet/Modem IP settings. OK, close, save or whatever is applicable. Rebootrouter. Connect DSL modem to router.
    Aug 02, 2008 | D-Link AirPlus DI-524 Wireless Router
    NetGear WGR614 Wireless Router Logo
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Brian Sullivan
    Brian Sullivan
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
