Ok, the paper jam ERROR could be due to one of the following:
- Check for paper in the paper tray
- Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
- Defective D-roller
- Debris in the paper path
- Gears not turning or broken gear
- Defective paper tray
- Broken input sensor flag
- Defective input sensor board
- Defective system cable 2
- Defective system board
- Exit Sensor flag (Fuser)
- Exit Sensor board (Fuser)
- System cable 1
If there is no bit of paper or
debris stuck in the rollers, it would indicate something more serious,
and in need of servicing. If your machine is under warranty, I suggest
you take it back to the shop and get it replaced or repaired under warranty.
If your warranty
has run out, then you'll either have to get it serviced or buy a new
printer (whichever works out cheaper for you)
Hope that helps!
dell printer 1700 still saws paper jam and ready i data any solution ??? pls pls help me
