Question about Samsung Office Equipment & Supplies
Hi, I have a problem while scanning. I have Samsung SCX-4521F. Wizard gives me only to the point where I can get scanned images - one by one. Doses not give me an option to scan several pages at the same time. Also, doesn’t give me option to scan as PDF file. Can you help me? Thanks!
    Guru:
  • 1,049 Answers
I believe these features have to be enabled in the administrative console with keys. There is a known issue on these printers where if it is shut down it restores the system defaults. If it was working then stopped, these features may have to be re-enabled by the printer distributor.
Posted on Aug 29, 2008
After reading data or scanning output is no clear
Hi Sunil
You can change the scanner setting and increase image resolution before scanning,after that your image will get clear. Download the mention below manual & read the software section para.
Download :Manual
Instruction :
  1. Go to the control panel and select the printer & scanner.
  2. Right click the Samsung scanner and select the properties.
  3. After that select the graphic tab and select the 600dpi and seve the setting
Now you can get the perfect image which one you need.
If my solution make you happy then give me thumb.
Jan 08, 2012 | Samsung SCX 4521F All-In-One Laser Printer
How do I activate the scanner on the SCX-4521F multi function printer?
Click this link http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000191&model_name=SCX-4521F
Go to Scanning, then How to scan.
You have to configure the printer first to scan. Follow the steps and you should be all set
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to scan a document on the scx-4521f
hi,
here is the the user manual for scx-4521f scanner. this will guide you to use the scan feature of the device.
cheers
Jul 23, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Scan format - Samsung SCX-4521F to PDF
samsung scx 4521f in black background in more verticle white line in
Feb 20, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I HAVE Samsung SCX-4521F All-In-One WOULD YOU ANSWER ME PLZ
Please chepue out the scanner ccd is not moving properly
when ccd is stop in one place the image will come sreached
or check the scanner cable or check ccd
May 10, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Scx-4521 imaging device driver, scaner
Try changing your usb printer cable with a different brand. I have had lost of machine not wanting to scan because of faulty usb cables, even though you can print it refuses to scan. If this still is not helpful, try downloading the latest drivers from samsungs website.
Mar 21, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Scanner not working
No solution, but the same problem with my iMac. Followed all installation instructions but nothing appears as the manual instructed. Called Samsung's HELP humber and was told, very **** , that they cannot provide support for a Mac. Really? Why does Samsung claim the SCX-4521 is "totally compatible" with Mac? Either change their claim or get somebody on the desk who has a solution!
Mar 05, 2007 | Samsung SCX 4521F All-In-One Laser Printer
101 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
