Question about Nikon Coolpix 5700 Digital Camera
What is moir?? (red/blue stripes)
In some of my photos I have an odd red/blue stripe or pattern. What is this?
    Novelist:
    Scholar:
  • 79 Answers
Sometimes odd stripes or colors will appear in a digital image, either from a high-end digital camera, or from a scanned image. This effect is called moir? and is caused when a fine pattern in the subject (such as the weave in a fabric or very close, parallel lines in architecture) matches the pattern of the imaging chip. When two patterns meet, often a third, new pattern is created. This third pattern is called moir?. In order to reduce (or eliminate) moir?, a special anti-aliasing filter is mounted in the camera. If too strong a filter is mounted an overall soft image will be produced, but with no moir?. If a weaker filter is chosen the image will be sharper, but there is more of a chance for moir? to happen in some circumstances. Nikon has chosen to produce the sharpest image that can be made, even though there may be some moir? in parts of some images. To help reduce moir? there are many techniques to use: Change angle of camera. Since the angle of the camera and subject causes moir?, slightly changing the angle of the camera (by rotating the camera) can remove or change any moire that is present. Change camera position Again, changing the angle relationship by moving left or right, up or down can reduce moir?. Change focus point Moir? is caused by very sharp focus and high detail on fine patterns; slightly changing the focus point changes the sharpness and can help to remove moir?. Change lens focal length Different lenses or focal length settings can be used to alter or remove moir? Remove with software Nikon Capture (as well as several third-party, Adobe® Photoshop® plug-ins) can be used to remove any moir? that does appear in the final image. Of course it may not be possible to remove all moir? in all cases, but in general an overall clean, sharp image with slight moir? is preferred over a soft focus image. Moir? can happen with images from all digital cameras and scanners, but is more likely to happen with an SLR-type digital camera system because the lens, sensor and software are designed to produce the sharpest, most accurate image possible. When reviewing images to see if moir? is present be sure to be looking at the image on the computer screen (or the camera's LCD) at the full, 100% view. If you zoom out on-screen a false moir? can be produced by the pattern of the monitor grill.
Posted on Aug 29, 2005
Does anyone know which colour does what for a madza demio stereo wiring harness
It sounds like the the ones with red and black stripes are possitive and negatives for your speakers then the others are positives also you would need a 12v test light to see witch wires have power to them and go from there
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_87482045335a4757
Sep 06, 2014 | Cars & Trucks
Fuji finepix 5600 white stripes
When you say 'played back', do you mean viewed on the camera screen, or after downloading to your computer ? If the latter, it could be to do with the software you are using - try FastStone.
Apr 18, 2017 | Fuji FinePix S5200 / S5600 Digital Camera
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Ripples appear in the image when photographing an object with fine plaids or stripes. Why is that?
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Picture ripples
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Picture ripples
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
What is moir??
Sometimes odd stripes or colors will appear in a digital image, either from a high-end digital camera, or from a scanned image. This effect is called moir? and is caused when a fine pattern in the subject (such as the weave in a fabric or very close, parallel lines in architecture) matches the pattern of the imaging chip. When two patterns meet, often a third, new pattern is created. This third pattern is called moir?. Notice in the illustration below the round, circular patterns (on the right) created as the two grids are combined; this is moir?. In order to reduce (or eliminate) moir?, a special anti-aliasing filter is mounted in the camera. If too strong a filter is mounted an overall soft image will be produced, but with no moir?. If a weaker filter is chosen the image will be sharper, but there is more of a chance for moir? to happen in some circumstances. Nikon has chosen to produce the sharpest image that can be made, even though there may be some moir? in parts of some images. Notice the red/blue stripes on the bottom of the bag (which should be solid grey) To help reduce moir? there are many techniques to use: Change angle of camera. Since the angle of the camera and subject causes moir?, slightly changing the angle of the camera (by rotating the camera) can remove or change any moire that is present. Change camera position Again, changing the angle relationship by moving left or right, up or down can reduce moir?. Change focus point Moir? is caused by very sharp focus and high detail on fine patterns; slightly changing the focus point changes the sharpness and can help to remove moir?. Change lens focal length Different lenses or focal length settings can be used to alter or remove moir? Remove with software Nikon Capture (as well as several third-party, Adobe® Photoshop® plug-ins) can be used to remove any moir? that does appear in the final image. Of course it may not be possible to remove all moir? in all cases, but in general an overall clean, sharp image with slight moir? is preferred over a soft focus image. Moir? can happen with images from all digital cameras and scanners, but is more likely to happen with an SLR-type digital camera system because the lens, sensor and software are designed to produce the sharpest, most accurate image possible. When reviewing images to see if moir? is present be sure to be looking at the image on the computer screen (or the camera's LCD) at the full, 100% view. If you zoom out on-screen a false moir? can be produced by the pattern of the monitor grill.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
106 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
