Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon camera problem
Hi, i have nikon camera and it says - error.press shutter release button again ,what shoud i do
  • Anonymous Sep 08, 2008
    I have a nikon camera. When i try to shoot, the camera freezes and says error. what should i do?
2 Suggested Answers
SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
Posted on Jun 01, 2008
Error press shutter release button again. After countless button pressing, message continues
When I have this problem on my D-90, I can usually fix it by turning the camera off and back on. Occasionally, I have had to remove and reinstall the battery. My D-90 manual says that this is a camera malfunction error and that it can be fixed by releasing the shutter. Unfortunately, when I have this error, the shutter won't release without turning the camera off. The manual also says that if this problem occurs frequently or persists to contact an authorized service center. I suggest you contact Nikon tech support at www.nikon.com, first, to see what they have to suggest.
Mar 17, 2013 | Nikon D3000 Digital Camera
Error!Press shutter release button again
error shutter press release button again
May 30, 2011 | Nikon D60 Digital Camera
My Nikon D60 "Error. press shutter release button
Hi
The error is with the shutter release button and the unit has to be taken apart....Get it repaired by Nikon it is a common problem with these units.
Thanks for using FixYa
Have a Nice Day
Jan 25, 2011 | Nikon D60 Digital Camera
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
D40 "Error: press shutter release button again." Nothing happens.
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
Dec 19, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Error code says press shutter release button again
I e-mailed nikon for this same problem. Their solution was to take out the memory card and press the shutter release button in the demo mode. To get to the demo mode you first need to go to custom menu/controls/no memory card?/press ok/ arrow down to enable release and press ok. Now you are ready to try solving this problem. Press the shutter release button to see if it will reset the shutter release button. I haven't tried it yet but it is worth a try.
Aug 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
When i take a pic,it says error press shutter release button again
Aug 24, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d60 shutter release error
press shuter release button again
Jun 22, 2009 | Nikon D40x Digital Camera
Error message on display
you might have a stuck shutter. have it checked by nikon..
Jan 28, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
Dec 28, 2008 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
169 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
