Question about Lexmark Office Equipment & Supplies
Prop Res DLL window keeps popping up when I open a word document. I cannot print tells me there is no printer connected which there is. Suddenly will then print helpppppppppppppp
    Guru:
  • 1,049 Answers
The printer driver is corrupted or additions associated with the printer are incompatible. Try printing from word to a PDF, MS Imager, or another printer. If you get the error you will need to look under tools > "templates and Addins" or "Options". More likely it is that printer only, in which case uninstall and reinstall the printer driver and software.
Posted on Aug 29, 2008
  • NA NA
    NA NA Sep 12, 2008
    Was this helpful?
When Printing Of the internet script error comes up and printer will not prin
which web browser are you attempting to print from? and is this through a windows pc or is it on a different os?
Jul 30, 2013 | Samsung Clx-4195Fn 4-In-1 Colour...
I've got a document to print and when I click print it tells me (in the jobs queue) it is idle. This has only happened within the last few weeks. How can this be solved?
Power Cycle the printer sometimes resolved a problem like this.
Go to printer properties
right click and choose see whats printing for vista and win7 and click open for windows xp
pop up window will open then click on printer and cancel all documents
this will clean documents stuck on queue
go to start and click search for win7 and vista or click run for win xp
type services.msc
pop up window will open then look for print spooler
click restart on the spooler then it will restart only the print spooler
try printing again
Issue
The solutions in this document address the issue of print jobs getting stuck in the print queue
A log of print jobs waiting to print
. The following symptoms might also accompany this issue, and this document does address these other symptoms:
Printer won't print
Printer is Offline
No response from product
Check the print driver and the port
If you ever installed more than one HP product on the computer, the product might not be the default printer, or the wrong print driver might have been configured. Follow these steps to check the print driver configuration.
1.
On the Windows taskbar, click Start ( ), click Control Panel , and then double-click Printers and Faxes . The Printers and Faxes folder opens.
2.
Look for a black checkmark ( ) next to the product icon. This checkmark indicates which product is the default printer.
Figure 14: Example of default printer icon
Illustration of the default printer icon in Windows XP
If the wrong product is the default , right-click the icon for the correct product, and then click Set as Default Printer .
If the correct product is the default , continue to the next step.
3.
Right-click the icon for your product ( ), and then click Properties . The printer Properties window opens.
4.
Click the Ports tab.
5.
Look for your product under the Description column, and then view the Ports column to the left.
6.
Select your connection type to determine which port you should use
Mar 27, 2011 | Office Equipment & Supplies
Prop res dll not loaded
Try reinstalling the printer driver.
Normal 0
You can download the Lexmark printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Oct 25, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark 6100 series error message Prop Res DLL not loaded
Download tatest driver sfrom lexmark and use revo to uninstall first
Sep 30, 2009 | Lexmark X6170 All-In-One InkJet Printer
I keep getting error 1-2070
Resolution
Check to see if the required files are present:
  • Go to C:\WINDOWS\system32\kodak. Check for 2 folders "kds_aio5000(for AiO 5000 series printers) and kds_aioesp(for ESP series)
  • Depending on printer model, open kds_aio5000 or kds_aioesp.
    • For kds_espaio it should only have the lib folder. It doesn't have the ekaiowia.dll
  • Inside the lib folder it should have cct.ekpgct, hippo.dll. Both for kds_aio5000 and kds_aioesp.
  • If hippo.dll is missing then try the following:
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Apr 12, 2009 | Kodak ESP 5 Printer
I can not print my documents
I will continue to test this and report if I encounter any problems.
The solution is to remove a monitoring component of the HP printer driver. Open registry editor and browse here:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
Delete the "HPLJ1018LM" 'folder'.
Also open Windows Explorer and browse here:
C:\WINDOWS\system32\spool\drivers\w32x86\3
Rename the file "ZLhp1018.DLL" to something else, such as "ZxLhp1018.DLL".
Restart your computer.
Sharing now works fine.
But if you are not sharing then check printer cartridge and if still problem then you follow the path:
1-open the control panel and click add/remove program
2-uninstall the printer driver
3-then new install printer driver
4-keep default setting of your printer.
Apr 07, 2009 | HP LaserJet 1018 Printer
My hp deskjet 3550 does not print
Unistall the printer(software) then let Windows reinstall the printer, only you have the drivers downloaded(from website link below) and tell it , the computer, where to find them, when asked.
http://h10025.www1.hp.com/ewfrf/wc/product?product=82029&lc=en&cc=us&dlc=en〈=en&cc=us
Feb 15, 2009 | HP DeskJet 3325 InkJet Printer
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
Sep 16, 2008 | Office Equipment & Supplies
Keep Printed Documents
Deletes and reinstall print drivers, does'nt sound like a printer problem, more software issue, driver reinstall is my best bet
What are you printing from? ie program is?, and can you print windows test page OK?
Dec 19, 2007 | Brother HL 5140 Laser Printer
If you have a Brother printer please change the following:
Start -> Control Panel -> Printers and Faxes -> Right click on your selected printer and select "properties"
Go to Advanced tab -> Print Processor
Change the settings from "BRMFC" print to "WinPrint" and set default to "raw" and Click Apply
Now go back to uncheck "Keep Printed Documents" and attempt to print the coupon.
I am a big fan of coupons.com, their tech support guy sent me these instructions. Good Luck!!
Nov 20, 2007 | Brother MFC 420CN All-In-One InkJet...
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
