Question about Yamaha RX-V461 AV Receiver
My yamaha rx-v461 won't turn on
I have all of my electronics plugged into a surge protector and all of my equipment came back on after a power outage accept my receiver. Does it have a reset button or something that I'm not aware of?
  • 1 more comment
  • krsoon Aug 24, 2008
    My yamaha HTR-5890 won't turn on problem, and notify you when a new solution is offered.
  • prashants3 Feb 16, 2009
    But there is no fuse any where on this unit (neither on back nor on front panel).
  • Anonymous Mar 13, 2014
    I guess the surge protector went off and disabled receiver. Is there a code to restart receiver?
    Genius:
  • Yamaha Master
  • 1,550 Answers
Check the main fuse
Posted on Aug 22, 2008
After power outage, no Sony logo, half screen turns white.
take it in for repair as the power surge has damaged the electronics on a board
quality surge protectors are the preventative equipment to be used for ALL equipment running electronic controls ( includes fridges and stoves,and air conditioners that plug in
Mar 05, 2016 | Sony BRAVIA KDL-52NX800 52" 1080p LED-LCD...
Tip
HOW TO PROTECT YOUR ELECTRONIC GOODS AGAINST POWER SURGES
I have only been giving advice on FIXYA for a very short while but have noticed that an awful lot of the people who relate their product issues , particularly complain about faults developing after power cuts / outages. It is apparent, from a description of the complaints, that damage is being caused by outages that may be a result of power surges blowing electricity sub stations.
There are a lot of damaged audio devices / tvs being affected. As such I advise you TO BUY SURGE PROTECTORS for all you valuable devices.
I have them around the house and although we only get an occasional power cut here in the UK I know that at times they have saved my equipment fron power spikes. The small cost is justified in the long run.
on Jul 20, 2015 | Yamaha Rx-v365 A/V Home Theater Receiver
Display on control panel no longer displays.
Surge associated with power outage can make disasters in refrigerators. You need a power protector for refrigerators.
Now, what already is damaged, should be repaired by an authorized techician.
For protector, you can do a search; typical return is this one
Electronic Surge Protector for Refrigerators up to 27 Cuft and Freezers
May 13, 2015 | Samsung RS277AC (27 cu. ft.) Side by Side...
I have a Yamaha htr-3065 HDMI receiver that won't turn on after we experienced a power outage. When I plug the unit in I get a buzz sound from transformer but still won't come on. The fuse and power supply...
If you have any electronics experience you should check the diodes or the bridge rectifier in the power circuit. Look for burned components or bulged capacitors.!!!Always unplug the unit and wait a few minutes before attempting any procedure!! I have found that capacitors usually fail due to voltage spikes which can happen when power is reinstated after an outage. Always use surge protectors on electronic devices. They have a component called an MOV that will absorb voltage spikes and save your equipment.
Oct 03, 2014 | Audio Players & Recorders
Yamaha RX V671 will not turn on anymore after a power outage
The protection mode has activated.
Reset the protection mode as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Apr 10, 2012 | Yamaha Audio Players & Recorders
What are the surround sound settings for a yamaha rx-v461?
It has many, depending on the your speaker configuration, the source hardware and the source material...
Read the manuals...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V461-Receivers-manual/id/2526ci760/t/2/
May 07, 2011 | Yamaha RX-V461 AV Receiver
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Power issue
Sounds like your power supply may be shot on your computer. You can get a power supply tester and check it. Not sure what to do about the printer. If you had a surge protector in between your computer and ac. Plug the computer and printer back in to the AC outlet directly and see if that helps. Hopefully only your surge protector is damaged.
Please rate, Thanks.
Feb 09, 2009 | HP PSC 950 All-In-One InkJet Printer
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Yamaha RX-V461 AV Receiver Logo
765 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
