Your main's power cord is easy to found at most of the electronic shops. It's the typical "figure of 8" connector, available also for some laptop's power supplies. You can also order one one line from
this link. Note that since I don't know where are you from, the plug for the wall-socket may differ from the one on the provided link, but it's easy to use an
adapter for your local area electricity. For example if you leave in Europe you can order the power cord from
this link that is fitting on the european electricity standards. In case you can use screwdriver and cutting tools you can also change just the plug for the wall socket (in case that the dog's chew is near this plug) with very low cost.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
I'm adding the console name, that is: Farfisa F1
