i have a rca r52wh74 with a chassis # ITC222A when i turn it on the colors are off about an inch from each other and the picture is bowed down form the top about 2''. I tried auto convergence and it did not work then when i went to do manual convergence it, convergence had dissapeared form the menu.
The 45 volts feeding the convergence amp power supply may be missing that is why convergenc is bad the heat sinks on the convergence amp cba are probably cold from not running that is why convergence is not displayed in the menu repairing the power supply will most likey fix it for you I assume you have a schmatic?
Was this helpful?
Yes
No
Solution #2
posted on Aug 29, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The convergence board is bad and can be componentlevale repaired for cheaper than a new one. But you will have to have a tech do the repair
My sony KP-65WS500 has a bad red picture tube. So I followed the earlier post to turn down voltage...
(More)
My sony KP-65WS500 has a bad red picture tube. So I followed the earlier post to turn down voltage and the red tube now works. But after its been on for about 4 or 5min the red fads alittle from the picture. Its not a big problem I was just wondering is this still the picture tube or could it be the bulb. The red also ficklers very slighty every now and then.
My mom just contacted me regarding a problem with her Hitachi 53SVX01B, where the picture is now...
(More)
My mom just contacted me regarding a problem with her Hitachi 53SVX01B, where the picture is now heavily biased in red and green. I speculated that the blue lamp burned out, and then she indicated that after watching for about 10-15 minutes, the picture goes dark, but the power indicator stays on. If she cycles the power, it stays on a shorter and shorter period of time, so I assume this is some thermal protection. She lives near Kansas City Kansas. Any ideas what the problems are, what the cost to fix might be, and who might be a service contact in that area?
I have a 42 in wide screen and it was unplugged for about a 2 months and when I plugged it back in...
(More)
I have a 42 in wide screen and it was unplugged for about a 2 months and when I plugged it back in the colors were not lined up right. I tried using the converge on the remote but it doesn't work.
i am in a pocession of a westing house tv lvm42w2 model and it has a mechanical problem and in...
(More)
i am in a pocession of a westing house tv lvm42w2 model and it has a mechanical problem and in need of a particular pafrts which includes: all i need is the the two back light inverter part number my email address is mablegoodas@yahoo.com please make note that the inverters is at the back of the said mentioned television. kindly respond in a expiditious fashion
