Question about Cameras
I have a picture that looks like a leaf when I switch the camera on and this block my view to do anything esle.
  • 10,594 Answers
Please mention brand name and model number of your camera to provide you help.
Posted on Aug 22, 2008
Hp r507
I don't think anything is wrong with your camera. Just check the Manual.
Your camera has a view finder, to make pictures. Yes the little screen on the top left (Backside) As an extra the camera has live view, that can be switched on and off. because the live view consumes lots of power, it is advised to use the view finder. If you want to switch it on, you can do so in the settings menu. There go to the live view en switch it on.
Feb 13, 2014 | Cameras
A few weeks ago, shortly after I'd taken a pic, the lens refused to retract and the camera switched off. It has never been dropped or had anything spilled on it. Strangely, when I press the button...
Sounds like a lens error. Look for sand particles around the gaps of the lens barrel (a single particle can jam it). Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 31, 2011 | Kodak EasyShare V1003 Digital Camera
Camera problem I have a Kodak Easyshare c190 camera and i went to the beach and you can not see ANYTHING thru the viewfinder. I tried desperately to turn every way and covering all around it but just could...
Viewing the screen in bright sun is a problem for 99% of point and shoot cameras. 1% still have an optical viewfinder you can look through to frame the picture. Also, looking at the screen with polarized sun glasses makes the problem worse. There's no solution except to upgrade to a DSLR camera.
Apr 15, 2011 | Kodak EasyShare C190 Digital Camera
Memory Full or something esle?
Can you use any of the buttons on the back? A common problem for this model is keypad failure due to the connecting ribbon strip splitting, over time, where it is folded over.
All the buttons on the back of the camera run off the same ribbon. Only the on/off and shutter/zoom button run from a different ribbon.
For the memory problem, this camera has an internal memory but it is very limited and requires an xd card to increase memory capacity. If you cannot use the keypad to view or delete pictures then try either connecting a usb cable to the camera and computer or removing the xd card and use a card reader to view pictures.
If your pictures are stored on the internal memory then obviously you will be unable to view them if your keypad is not working and only by connecting to your pc via a usb lead will you be able to upload and view your pictures. You should also be able to delete them from the camera when plugged into your computer once you have uploaded.
Oct 16, 2009 | Fuji FinePix F470 Digital Camera
Canon powershot A520 doesn't work in camera mode. I can look at and edit pictures in viewing mode, but switching to "camera" won't let me take pictures... in this mode it also lets me view pictures already...
Do other buttons work? If so, the switch could be broken because it sounds it doesn't switch to the CAMERA mode, just stays at the VIEW mode.
If you're not experienced in repairs, you should give it to a local repair shop or Canon service center.
Sorry for the bad news. I repair these cameras very often.
Sep 27, 2009 | Canon PowerShot A520 Digital Camera
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 12, 2009 | Cameras
Did not get a disc with my dpix 5200 camera im unable to send pic
Prakticam, unhelpfully don't have anything for their cameras more than a couple of years old and don't seem to care if you mislay the disc you paid for.So be warned, don't buy Praktica. I have the 5200, you have firstly to put your usb in computer, switch on camera, switch camera to view pictures taken mode, and because it auto switches to take picture mode you then carefully attach camera end into camera whilst camera is still switched on! Then go to my computer and click on F: the pictures download. Then to save them click on first pic, hold shift key down and then click on last pic they should all highlight, right click and then hover 'send to' and send by left clicking to my documents. I remember that it took me 4 hours to work it out. Found this looking for manual to download, cannot change date now......
Apr 08, 2009 | Praktica Dpix 3000 Digital Camera
Screen problem??
This sounds like a cracked screen.. a leaf you say? is the leaf a graphic, perhaps an icon.. is it centered on the screen at all?
I would take it to a certified repair center to see if they can replace the LCD panel.
Sounds like it needs to be replaced.
Oct 31, 2008 | Cameras
The Monitor on my Nikon D80 does not show any image when I try to take a picture - The viewfinder is ok and the camera takes a picture ok and displays it for about 4 seconds on the monitor after taking it....
You can switch it off so as not to show the picture after you take one.
You cannot use the monitor to show images as you're taking them. The D80 does not have a Live View capability.
Sep 19, 2008 | Nikon Cameras
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
