Improper functioning of y5
My wireless local area neywork not functioning
what software i will use
plz tell me
    Guru:
  • 1,049 Answers
There is a lot that can effect this. To give you a good answer I'll need more information.
  1. What type of router are you attaching to
  2. What type of wireless device are you using
  3. What Operating system and is this a laptop
  4. Are you on a company network using WEP
That said...
You may need to change the wireless software to be managed by Windows and not the 3rd party software or vice versa. Different wireless routers work better or worse with different products. You may also need to enter the WEP key if you are using one as it's hash value and not as the word/words you setup. Also keep in mind that some wireless devices like the Netgear USB, can not operate well as a service and will not initialize as a result until after you are logged in. This means on a domain for example, you will have to log into the network at least once on a LAN line before you will be able to attach over wireless.
Posted on Aug 29, 2008
Panasonic y5 fan
What about the fan? If it is not working you will need to replace it or the laptop will run hot and shut down.
May 29, 2012 | Panasonic Toughbook Y5 PC Notebook
My wireless mouse wont work
The wireless mouse functions with batteries. Snap open the location area at buttom of mouse to either check for misalligned batteries or dead batteries requiring replacement. Also, the wireless mouse has an adpater cable that is connected to the computer USB area from where signals are acquired during functionality. Make sure every connectable cables to the computer are firmly in place. Sometimes, the computer may require restarting to capture wireless establishments if an disconnections were encountered once computer was still on. Make sure every connectables are firmly in place, restart the computer for desired functionality. Also, a restart of the computer should diagnose the malfunction of mouse attachements. Improtant notes: A new wireless mouse may have required installation of softwares, opening the computer wireless devices estblihment area to regulate captions on the new setup priop to first acquisition of wireless mouse functionality. Good luck
Jan 11, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
How to hook up the wireless feature???
Press the wrench key on the printers front panel and then look for wireeless option or network option in the menu..Press ok on wireless menu or network option and then look for an option Run Wireless setup wizard by pressing right arrow key...then press ok on that and type in the neywork name of your wireless router known as SSID and after that press ok...then type in the security key of your wireless router known as WEP or WPA Key,,press ok.. it will attempt to connect and wil give u a message successfull..now run the software on computer and select wireless install option on computer and follow the instructions
Sep 02, 2010 | HP Officejet 5610 All-In-One InkJet...
I need to get and install wireless adaptor software
Plz clarify which driver You want.
Plz tell model of ur pc/laptop
Jul 16, 2010 | Computers & Internet
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Connection using DSL-2640T
Try diagnose and repaire the connection if that does not work Reset your modem it should go back to default manufacture setup.Then turn modem off and connect any computer or laptop to the modem with ethernet wire turn the modem on go back to your computer that you are connected to modem with wire go to network connections and disable the wireless Network connection and enable local area connection once you see you have connected and have internet working go to start menu you can do this on the start search bar with vista or run with any other windows version type cmd and press enter, it should bring a DOS command menu and then type in ipconfig and enter scroll up and down to where you see default gateway type that ip address to your internet browser it should take you to login screen username should be administrator password admin setup your WEB key make the wireless access available DO NOT FORGET to write the web key down, give a name to the connection and change the default password from admin to something you can remember. save the settings and turn that off keep the laptop on. Then unplug the ethernet cable and switch the network connectiion again enable wireless disable local area also you need to scan the available wireless internet and pick the one you just named use the webkey to access and save when the connection in made.
Feb 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Plz tell me how can i install wi fi driver in my lenovo r60
Here is a list of possible drivers for your system from the Lenovo Support website. Make sure you select the proper driver and you should be good. Hope this helps.
Jan 21, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Microsoft Wireless Notebook Model 1023
windows should come with drivers for it, but microsoft.com has a full suite of intellipoint drivers available for all its mice which adds functionality windows drivers don't give it. If it is not working at all the problem is most likely not driver related.
Aug 02, 2008 | Microsoft Wireless Notebook Optical Mouse...
Wireless not functioning
HI there,
Check the hardware. Most network problems stem from improper software and hardware settings, but occasionally hardware failures are responsible. If a shared Internet connection seems to be down, try to watch a cable television channel if you have a cable modem or use the phone if you have DSL (Digital Subscriber Line) to see if the entire service is down. If it is, contact your ISP to see if there is a problem in your area. Check all cable connections and consider replacing Ethernet cables if the problem seems to be confined to a particular computer or device.
Click on the HERE..
Thank you & post back how things get done..
May 21, 2008 | Toshiba Satellite M45-S331 Notebook
Adding a second oomputer to network, have router on one, have USB wireless product for second?
well if your router is wireless it should be straight forwards,make sure the router wireless function is turned on in the router, the software that came with your usb wireless product will have a function to find all wireless broadcasts in your immediate area, select your one ,make sure,that if you have used a security key(such as WEP), that you use it also in the software of the usb product.
good luck
Terry
Mar 26, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
