Question about Haier HVF042 Wine Cooler
Wine refrigerator My 42btl Haier wine refrigerator is running too cold at 31 degrees. What is the problem or potential problem??
  • 5 more comments
  • sinks Aug 22, 2008
    My 6.5 yr old Haier Wine Cooler is running too cold. I set the cooler on it's normal setting of 55-60 degrees(in the front of the cooler). It will then plummet to 31 dgrees and stay there.As a result the wine is way too cold. I have tried this numerous times and it still plummets to 31 degrees I don't belive there is a thermostat knob anywhere on this cooler. What do you think the potential problem is???
    My unit has worked fine up until now.There is no manual temperature control other than the 2 buttons in the front of the unit, which is how you control the temperature for white and red wine. There are only 2 settings for the temperature and neither of them work. I believe these units come manufactured this way from Haier.
    How confident are you that it's the theromstat?? I have heard it could also be the sensor for the unit?? Also, can a layman install a new thermostat on these units???
    If I ordered a thermostat can a layman like me install it or do I have to get a tech to install it??Do these thermostats come with instructions?? Also, what do you mean by Gas. Freon???
    I hearing a couple of solutions to my wine cooler problem. Are you confident that it's the control panel. I know that's probably a big job, no worth investing in, particularly in a 7 yr old wine cooler.
    do you think it's the thermostat or the control panel???
    Yes, but not totally.
    Genius:
  • 1,269 Answers
Is the unit turned on always? How about try to turn it off for like 5 hours, unplug the power cable.
Posted on Aug 22, 2008
  • 1,879 Answers
Just to be on the safe-side, better have the new thermostat installed by a qualified technician.
    Master:
  • 521 Answers
Its the problem with the control panel for sure.many of my clients face this problem.and it gets solved by replacing the panel board.though i have tried reparing the control panel board but it does not work for long.i advice its always better to get it replaced by some good technician.any thing else let me know.please do rate the solution.thanks.
  • 157 Answers
Hi
It seems you have a problem with the thermostat mechanism in the fridge.
The only way to fix it is to get a technician to replace the thermostat and that should resolve the temp issues.
Another possibility is that the gas tank is empty and needs to be refilled with gas. Again, youll need a technician to do that
Hope that helps
Regards,
JigSaw
Fixya Team
    President:
  • 1,450 Answers
Http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1224608&PPStack=1
here is a link to the thermostat you probably need to replace this
  • 435 Answers
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • Try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Let me know if this worked.
Thanks
  • Narmada Anand
    Narmada Anand Aug 22, 2008
    If there is no thermostat the other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, It is better to recommend a qualified contact appliance repair technician.
    Thanks
  • Narmada Anand
    You would have to get a technician to install the faulty part. As you said, it is your choice if you would want to invest in a 7 year old cooler.
    Genius:
  • 2,035 Answers
Check Temperature Control In Unit To See Where It Is Set. If Set Too Cold Adjust To To A Warmer Setting And Allow Several Hours For Temperature To Adjust.
Good luck...
  • 10,594 Answers
You can control its temperature by its thermostat control knob.
I need the Haier 18 bottle wine cooler instruction manual.
Hi There,
I was able to find two 18 bottle wine coolers on the Haier site.
The first is model number HVTM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtm18dabb
The second is model number HVTSM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtsm18dabb
On either product page the manual can be downloaded from the "product support & downloads" tab
Have a great day!
Jul 18, 2012 | Refrigerators
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
Temp. is on automatic settings for "Red Wine" but fluctuate between 51-59 degrees, not to mention makes all sorts of noise (common refrig. noises) is this normal? Haier 35 bottle wine refrigerator
temps will fluctuate. depending on door openings and defrost cycles.no abnormal noises heard on the ones ive worked on but appliances tend to be noisier then they were. if less than a year old have an authiorized servicer go out and look at.
Sep 16, 2009 | Haier Refrigerators
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Does not chill drinks
you wrote that the wine cooler "only cools to 12 degrees minimum" I don't understand the problem?
12 degrees is really cold, in fact its freezing.
Oct 29, 2008 | Sunpentown Platinum Trim Cabinet...
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Oct 28, 2007 | Haier BC112G Wine Cooler
Haier HVF042 Wine Cooler Logo
400 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
