Question about GE WCVH6260FWW
Not spinning My GE frontloader doensn't spinn.Ican hear the motor running,but the drum isn't moving.Where is the belt located?
  • 4 Answers
The problem may be the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Posted on Nov 19, 2008
    Sergeant:
    Novelist:
  • 166 Answers
The belt is located in the back of the machine
You have to remove the top of the machine and then remove tha back cover. then you can see where the belt is, you will need some tools to replace the belt a socket or wrench us needed to adjust the motor pulley position so that you can get the new belt in place then you need to move it back to tighten the belt so it wont slip. its not a difficult job just make sure its disconnected from the power when you do it
Posted on Aug 22, 2008
  • 876 Answers
Your machine may not spin because the drain is plugged. Please check, by removing the drain hose at the back of washer and checking for a plug. Be sure to turn off your machine and unplug it , and have old towels and maybe a bucket on hand. Are any household drains running slowly? This could indicate a larger drainage problem.
Thank you for uisng Fix YA and good luck to you.
SOURCE:
Frontloading GE will spin to wash, but not to rinse
http://www.geappliances.com/service_and_support/faqs/faq_washers.htm
May 18, 2015 | GE Washing Machines
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
My brand new GE profile frontloader dryer quit spinning. Still blows and I can hear the motor. Other than that no odd sounds and the drum spins manually without resistance. Model DPVH890EJMG How do I fix...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2010 | GE Dryers
Ge electric harmony dryer fan motor not turning just moves side to side 1/4 of an inch back and forth . fan freeweels free, if i spin it buy hand.
with belt off see if motor free spins .the blower wheel should not free spin with the belt on and entire drum will turn with it otherwise you could have a bad motor and a blower wheel
Jan 24, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
GE washer wssr2070v1 will not spin.
If you hear the motor running but nothing is happening then check the belt on the bottom of the machine and the brake to make sure that the belt is not broken or stretched and also that the brake is not holding the drum
May 23, 2009 | General Electric WBSR3000G Top Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
GE WCVH6260FWW Logo
262 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
