Hotpoint aquarius super silent wf640p
Hi, my washing machine is no longer super silent, in fact it sounds like a train coming through the house, so bad we have to close the living room door when it`s on spin cycle. The machine is about 3 years old so it has plenty of life in it.
I have dismantled it and found that the clips on the drum paddles are worn down but everything else is ok as far as i can tell. There does not appear to be any play in the drum bearing assembly.
Please help solve this mystery so that we may live in the super silence we`ve come to expect.
  • 1 more comment
  • jaffa65 Aug 22, 2008
    My washing machine is only about 3 years old and is a front loader sitting on a concrete floor that is covered in vinyl floor tiles.
  • jaffa65 Aug 24, 2008
    Thanks guys
    I will investigate the problem further and keep you posted.
    cheers.
    jaffa65.
  • Anonymous Mar 30, 2009
    mine dos the same its on a first floor concrete floor and its driving me nuts
  • 639 Answers
You can buy rubber booty's for the legs of the washer!
These are commonly used when the washer is on a 2nd floor!
Posted on Aug 24, 2008
  • Neil
    Neil Aug 24, 2008
    Neil
  • Neil
    Neil Aug 25, 2008
    PLEASE GIVE ME A GOOD RATING HERE ON FIXYA .COM
    NEIL
  • 876 Answers
What type of floor is your washing machine sitting on? This may sound like an odd question, but it matters. Is this a front loader? Or a top loader?
Posted on Aug 22, 2008
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Aquarius wf620 super silent washer has "test" in
  • to de- activate press and hold the start/cancel button untill all the lights come on.
  • then press and hold the on/off and start/cancel buttons together until d-off appears
that should do it and if not get back to me, there is another way you can do it.
Jul 11, 2011 | Hotpoint Aquarius WF220 Front Load Washer
My HOTPOINT Aquarius + super silent will not tumble dry. it starts off OK but then comes up with Error code F-13 can you tell me what this means
Hello
F 13 is a fault code for water supply,inlet valve or hose connections.
You may try unplugging the machine and plugging back in to reset.
Mar 31, 2011 | Hotpoint Aquarius WD640 Front Load...
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Wd640 stuck on test
hold both buttons in until dsiplay clears
Jan 27, 2009 | Hotpoint Aquarius WD640 Front Load...
My washe keeps reading either F04 or F05
F04 - Pressure switch jammed on empty while F05 is a blocked filter.
Check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an engineer.
This really is your only option.
Plz rate my solution
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Hotpoint Aquarius super silent
Try pressing the "on" and "start" button together for over 5 seconds..............or till the display vanishes. You will tell me the result...............vote too.
Mar 17, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Led flashes on then off
did you find out what this problem was?
Dec 07, 2006 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
314 people viewed this question
Top Washing Machines Experts
