Question about Microwave Ovens
I am looking fom a cercuit board for a Magic Chief micro wave. model no. MCD 1311st S/N 40112130. the S/N of the ceruit board is: 3514315410-5 made by Daewoo. the transformer is not working. that part number is:DMR 631P 5EPU035303 DY 318 C
  • DrJBaz Aug 25, 2008
    I do have burn spots on the top and the same stains at the base, I also checked the 12 colt regulator and I have an open contact on one post. So I think I'll need both of them. Do you know where I buy those two?
    Thanks Jim B.
  • William Miller
    William Miller May 11, 2010
    Are you sure the low voltage transformer is really bad?
    Did you measure it at the transformer terminals or does it have a dark / burned spot?
    Sometimes as surge will damage the board, but the transformer will be okay.
    If you do need the transformer, you won't be able to order it from Magic Chef. You'll have to order the Samsung number.
    Can you post clear photos of it so i can see how the numbers ar arranged?
MicrowaveSvc
  • 9098 Answers
SOURCE: Heard a loud glass breaking
Does it seems to run louder?
I would suspect a shorted high voltage rectifier diode.
We have the full service manual and have uploaded it to our site here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2008
rickzilla
  • 706 Answers
SOURCE: i have a micro wave
This is due to a Defective control board..You will have to replace it , it is a design flaw.This has been a longstanding problem on the control board. You can remove and replace it yourself ( you will not void warranty) or you can have a GE service tech do it.. Good luck !
Posted on Sep 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 24, 2008
SOURCE: goldstar micro wave model number MVH1615WW
Could be the high voltage capacitor or the diode. Both can easily be checked with the proper ohm meter. It could also be the magnetron tube which you really cannot check. Bill
Posted on May 02, 2009
  • 949 Answers
SOURCE: micro wave not working jen air
The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
Sorry
Posted on Apr 24, 2010
Electrical wiring for mcd 1611st the microswitch the normally open and normally closed
Many micro switches have markings of "NC" and "NO" and "C" on them; indicating which terminal is what. You might be able to get a schematic for this on the Magic Chef web site.
May 06, 2014 | Magic Chef MCD1611ST Microwave Oven
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
PAPER DIRECTIONS
That FCC number means it was made by Daewoo, but it may have a Magic Chef or other brand name.
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
For Magic Chef in Canada call 866.587.2002
Jun 05, 2013 | Magic Chef Microwave Ovens
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Micro wave broke
open the door and look on the middle top right inside the microwave is it burned or blackend?You have a faulty magnatron.if it is.
May 19, 2009 | Magic Chef MCD1311ST Microwave Oven
Microwave Oven
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
The overheating concerns me. I would suspect that your turntable may not be working, or if so equipped, the stirrer may be stuck.
Or overheating is often a sign of a magnetron that's ready to fail.
I would look for the waveguide cover, clean it as needed as noted above, and look for any signs of charring.
Once you know it's clean, i would stay close when using it. If it works, then it may be okay. If it continues to arc or overheat, i would say the magnetron is dying.
Please write back if you need further help.
Sep 17, 2008 | Magic Chef Microwave Ovens
Dead microwave
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Please write back with your brand and model number if you need further help.
Jun 30, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
397 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
