Question about Mitsubishi VS-60805 60" Rear Projection Television
Convergence gets very bad the longer the TV is on.
When I turn my Mitsubishi VS-60805 on, most of the time the picture looks pretty good. Other times, the blue is so bad, it casts an annoying hue over the entire picture. When I go to the advanced convergence, the blue is almost a half moon shape. Then it may come back good for a while, then go bad again? I'm afraid the power supply is going bad. Can you give any advice or part numbers to order, and from where? Thanks.
  • Anonymous Aug 25, 2008
    Mitsubishi VS-60805:
    Blue convergence is out of line. Need assistance in locating parts.
  • 85 Answers
The convergence amps will have number on them starting with STK replacing thes may do the trick or you may just have a poor solder connection at these ic's try soldering them first if no go then replace them look around on the convergence amp cba on the bottom for obviuos bad connections small ring crack are hard to see these ic's work hard that is one reason for their large heat sinks running the set and turning it on and off may have induced fine ring cracks. i amsorry I dont have a schmatic for this set but the ic's do have their (generic) part number wrote on them as do most all transistors and diodes and ic's
Posted on Aug 31, 2008
All colors are out of alignment. It is fine but after watching it for about 20 min. It will fall out of alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 05, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805
What you probably see is a burning area due to Cooling Fluid leaking from one of the CRTs. If this is the case, It is not worth fixing in my opinion because the Board would have to be replaced and the leaking CRT would also have to be replaced. The availability of the Board is doubtful Due to it's age. You can check at 1800-553-7278. This is Mitsubishi's parts department #.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
I have a VS 60805 and i need a Convergence Generator. They say these are no longer Available. Any Suggestions?
General Consensus is that Mitsubishi is a Piece of ****, has been for a long time and I was lucky that my Set worked as long as it did. I guess it is just another benefit of not have any national product in the US anymore. No matter I will never Buy Mitsubishi Again.
Jun 25, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS60805 screen
If I can't get my 60805 working properly again I may soon have one :-)
I'm located in Orange County, CA, so if you're close I may be able to help you out.
Jun 16, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Where can I get good E2PROM settings for Mitsubishi VS-60805?
I have this model and just got it working again. I have a Service manual also. But unsure about checking my settings
Jan 30, 2009 | Mitsubishi VS-60805 60" Rear Projection...
No picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Jan 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS 50805/60805 blue/yellow shadows on screen
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple do the above
Aug 17, 2008 | Mitsubishi WS-55807 TV
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
285 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
