Question about Kodak EasyShare C360 Digital Camera
Pictures are not the quality I expected
My pictures are not the quality I expected. What can I do?
    Scholar:
  • 114 Answers
Use the Quality setting on your camera to select a picture resolution. To change the quality setting: Press the Menu button. Select Picture Quality, and then press the OK button. Select the Picture Quality setting you want to use, and then press the OK button. Press the Menu button to exit the menu. NOTE: The setting remains until you change it.
Posted on Aug 29, 2005
How much can I expect to spend on an elliptical trainer?
For a well-made, dependable machine you should expect to spend at least $1,000. This does not mean that you cannot find machines for less, simply that the quality of those cheaper machines may be of good quality. These lesser quality machines may require constant maintenance and ultimately have a shorter life span; thus making it beneficial to save up for a higher quality machine.
Aug 02, 2012 | Exercise & Fitness
Photo quality very bad
Nokia C3 has a 2 megapixel camera. You cannot expect very high quality pictures with this phone. But you can adjust the settings to bring out the best from what your phone offers. Lower the 'Resolution' to about mid-range because the photos will be blurry when it's on highest resolution. Try different resolutions and check what's best.
Apr 08, 2012 | Nokia C3 Cell Phone
If i use a 128MB card how many pictures will it hold
It will vary based on the pixel size of your photo. At worst case, take the pixel size of the camera and divide the memory stick by that. For example, a 3.2 MegaPixal camera, at highest quality, can get about 40 pictures. If you reduce the quality from the best or the size of the photo, then you will get many more pictures. With Sony, Sony uses a compression method that gets usually double the pictures at the highest resolution. Expect about 60 pictures with a 3.2 camera (do the math on other resolutions).
Mar 31, 2012 | Casio EXILIM Digital Camera
My BD530 player doesn't play all movies clearly. Some come cover good others re all snowy
When properly connected to a High Definition display or TV, Blu-Ray Disks (BD) should play crystal clearly. Inserting an old "non-Blu-Ray" disk (or the original "DVD") in the Blu-Ray player will display a comparatively "fuzzy" picture. This is the difference between High Definition and Standard Definition. A "BD player" can not "upgrade" the picture quality on DVDs to that of a BD or High Definition picture.
Rent, purchase or choose Blu-Ray Disks (BD) whenever a choice is offered to view the High Definition version of a movie or video. Selecting the DVD version will provide the lower quality or Standard Definition version of the same movie or video.
Check the covers or disk itself to determine if the movie or video is in DVD or BD format. That will tell you what you can expect for picture quality.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 17, 2011 | LG Super Blu BH200 Blu-ray and HD-DVD...
Screen is too dark. Have trying the auto adjust, itsn't helping.
Auto adjust would retore the screen to what is usual of the Tv not the users expectations. Usimng the brigtgness contrast buttons to control a picture quality accustomed.
Jan 29, 2011 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Poor print quality
Clean the print head again .......
Sep 07, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Green Tint Over Entire Printed Picture
I had a very similar problem and found out that the problem was the quality of paper I was using. Remember, a photo printer is expecting high quality results. Cheap, low quality paper will not accept the ink as well as higher quality paper. I can't guarantee this will solve your problem but I have not had any green tints since switching to a higher quality photo paper.
Jun 27, 2008 | HP Photosmart 8150 InkJet Printer
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Kodak EasyShare C360 Digital Camera Logo
135 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
