Question about Kodak EasyShare C360 Digital Camera
My camera screen displays a "No images to display" error message. What should I do?
    Scholar:
  • 114 Answers
This error message means that there are no pictures in the current storage location. Change the picture storage location setting.
Posted on Aug 29, 2005
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Reads zoom error when turned on
The device requires restoration achieved in two processes
perform a check
1. Power off completely the camera.
2. Remove all power devices or batteries
3. Check the entire device for damages
4. Make observation notes about any malfunct features
5. Replace batteries and removeavble parts properly with caution that every feature is intact.
6.If the device still displays error message consider the second phase explained
a. The device program features are jammed only possible solution is performing a software update or upgrade
1. updates are achieved by contacting the device;s technical support deparment
2. Upgrades can be performed by acquiring an installation kit in which instance requires technical expertise to perform an intergration restoration
Important notes
1. Apart from the message received does the device malfunction?
2. Your camera would be displaying an image similar as flash screen or screen saver that can be fixed quiet easily
a. use the menu buttons to select the option of settings
b. set the picture to be displayed on the appears screen area once powered on.
c. Possibly alter the entire image displayed as desired by yourself.
4. A screen saver could only be deleted,, hidden, or replaced with a preferable image
5. Possibly, the words ZOOM ERROR could changed to WELCOME TO OLYMPUS STYLUS
Refer to the camera manual for diagnostic support
Dec 02, 2010 | Olympus Stylus 730 Digital Camera
Sony cybershot P200 says 'File Error'
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files. I suggest that you transfer the images from the Camera to the computer and check if it works. After transferring the images, get the Memory formatted from the Camera and start capturing new images. The edited images will not get displayed in the Camera again. Please try not to edit the images in the Computer without transferring it.
Thanks.
KenSolutions
FixYa
Sep 12, 2010 | Sony Cyber-Shot DSC-P200 Digital Camera
My screen displays blue screen and 'file error', it then seems to delete the photos as I cant find them.
Please Power Reset the Camera and check if that helps.
Please turn OFF the Camera.
Then, remove the batterypack from the Camera and press the Power button for 30 seconds.
Next, reinsert the batterypack, then turn ON the Camera and check if it works.
If the issue still persists even after performing the Power Reset procedure, the Camera requires to be physically examined to determine the exact issue.
Thank you!
Mar 24, 2010 | Sony Cyber-shot DSC-H50 Digital Camera
''Unable to display this image'' error on Pentax Kx
Sounds like some of the spaces on the card are becoming corrupted. How do you download? With the camera and USB cord, card inserted into reader on computer, or card inserted in a separate card reader? When you are finished downloading, do you use the "safely remove hardware" icon at the bottom right of your computer screen or do you just yank out the cord or card thereby causing the corruption?
Feb 11, 2010 | Pentax Kx Body Only Digital Camera
I have a DSC T70. Sometimes i get a message "File Error" for some of the pictures. For these pictures, the file does not show and when printed, the picture is merged with another picture.
The LCD screen of the Camera may display a FILE ERROR message when trying to view a still image on the Camera if the image was rotated, modified and overwritten using editing software on a Computer.
To play images you have taken on the Camera, it is recommended that you do not make any changes to the original image files.
Aug 28, 2009 | Sharp Cameras
Unable to display imges when connected to computer.
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jun 09, 2009 | Canon PowerShot A460 Digital Camera
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Kodak EasyShare C360 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
