Question about Haier HVF042 Wine Cooler
Haier Wine Refrig runs to cold
When I set my wine refrig. (about 2-3 years old) to 55-60 degrees within a few days it igoes down to 37 degrees. The wine is truly at 37 degrees the temperture gage is showing the correct temp. Why won't it stay at its setting of 55-60? Is it the temp. gauge, sensor or ???
Haier HVF042ABL
Change your temperature sensor, it's broken and it's going to down temperature
Posted on Sep 03, 2008
What are best dates to drink red wine?
There is no magic date. Just make sure to chill it for a hour before drinking. I know it sounds weird but that is how it is done. For white wine and it's been in the refrig. you need to let it sit a hour before drinking. Most folks drink white wine too cold and red wine too warm.
Sep 06, 2014 | Wine & Spirits
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
MY WINE REFRIG CLICKS ON AND OFF AND IS NOT COLD WHAT IS THE PROBLEM?
try to clean your condenser and chek your condenser fan if working replace if not
Mar 27, 2011 | Haier Refrigerators
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
Temp. is on automatic settings for "Red Wine" but fluctuate between 51-59 degrees, not to mention makes all sorts of noise (common refrig. noises) is this normal? Haier 35 bottle wine refrigerator
temps will fluctuate. depending on door openings and defrost cycles.no abnormal noises heard on the ones ive worked on but appliances tend to be noisier then they were. if less than a year old have an authiorized servicer go out and look at.
Sep 16, 2009 | Haier Refrigerators
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Oct 05, 2008 | Oster 12-Bottle Wine Cellar - Black
Does anyone know how to lower the temp below 45 degree's.
Dear friend,
ngfam at you service! happy to assist!
No they have no bypass!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 07, 2008 | Haier BC112G Wine Cooler
Haier HVF042 Wine Cooler Logo
530 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
