Question about LG LSC26905TT Side by Side Refrigerator
How do you replace the handles on the doors
I purchased home and the handles are both scratched . I ordered new ones from LG but I don't have a parts catalog to see how they are attached.
  • dcb328 Aug 22, 2008
    I found my own answer in the owners manual. Just grab the handle and lift up. They come off easily.. Page 7 of the owners manual..
  • 639 Answers
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
USE THE OWNERS MANUAL!!
THEY SHOULD SLIDE UP!!
USUALLY ON MOST FRIDGES THERE ARE SMALL PLASTIC CAPS THAT POP OFF AND THE SCEWS ARE CONSEALED UNDER THEM.
SOME HAVE ALLEN SCREWS IN A HOLE ON THE SIDES OF THE HANDLE
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Posted on Aug 26, 2008
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Model wm 16331FD
this is not the right site for your question but why don`t you go to an appliance store and get the part it can`t be that expensive.
Sep 05, 2014 | Cars & Trucks
My new LG front load washer has a deep small scratch in the outside of the plastic door. Should i be concern
Take the reimbursement because the minute scratch is not effecting the performance and you are the only one who is aware of the condition. As for the noise, a bit of One Lube spray on the hinge will take care of that. One Lube is a special oil/silicone application that works on all moving parts that tend to make noise, and it lasts far longer than all other products. Look for it on the internet, or ACE Hardware.
Apr 15, 2014 | LG Wm3470hva Wm3470hva Front Load Washer
Inneed to replace the door handle. I have the
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER.
If you have any questions, please post back and let me know. If the model number you listed this quesiton under is correct, you can refer to pcappliancerepair.com for some excellent exploded view diagrams of your microwave that confirms how the door is assembled. The part numbers for a new handle (if you haven't purchased one yet) are: 8169737 - (White) 8169738 - (Black) 8169739 - (Biscuit) 8184264 - (Stainless) Make sure you use the correct part number when ordering to ensure you get the correct color to match your appliance. I hope this helps you.
Feb 17, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I need a schematic for an over the range microwave door in order to replace the handle. A samsung model SMH7187STG
Do you have the new handle already? I need a whole new door due to a scratch and will have a new handle from the scratched door that I wont need........
Oct 25, 2009 | Samsung Microwave Ovens
Handle broke off, model # khhs179Lss-4, wna to
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
If you have not purchased a new door handle yet, the part number is 8205431 (White), 8205433 (Black), 8205432 (Biscuit) or 8185456 (Stainless). A new one can be purchased at pcappliancerepair.com for about $40-46. Make sure you order using the correct part number to ensure you get the right color.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 16, 2009 | Microwave Ovens
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
1997 buick park ave 4 door right front door handle won,t work from the outside
Order the exterior door handle AND the clip that attaches the rod to the exterior handle from your local dealership ( any part in the salvage yard will have at least as much wear as the one U are replacing ) Also order a can of touch up paint matching your car. After you have the parts and have painted the new exterior handle, roll down the window and remove the interior door panel. ( instructions have been posted at 'replace door lock buttom' ) Two nuts, one on each side, hold the broken handle in place and must be removed ( DON'T loose them ). Loosen the rod from the clip at the top to allow a bit more room, But take note on the way it is attached ( you will need to reattach the rod to new handle ) To install new mechanism put the new clip on the rod, carefully place the gasket and the new handle in place and install nuts to secure. Test the door handle and make sure it works. Reinstall interior door panel.
Jul 06, 2009 | 1997 Buick Park Avenue
Long scratches on my LG Titanium refrigerator door. Is there a way to fill or buff out?
Unfortunately there is no way to fix this problem. The doors can't be "buffed" out to repair scratches. The only way you can fix scratches on the refrigerator is to buy "touch up paint" from LG and it is only for the sides of the refrigerator. To fix this problem you will have to purchase a new door. You can call LG Parts Dept. 888-393-6484 to purchase this door.
Apr 28, 2008 | Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
106 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
