Question about Dell OptiPlex GX620 PC Desktop
Reinstall windows xp pro
Hi i hawe DELL Optiplex gx620 i hawe problem reinstalling windows xp pro after after i install windows vista,i try to boot from cd but do not works after setup apers no nothinkg muvs.pleas help.sorry for bad english.
  • Bajram Aug 22, 2008
    setup get as far as setup apear asking to pres; Enter to run setup,pres R to repaire'pres F3 to exit. and just stops ther I pres Enter to continu but nothing.I did not formate HDD.I thot just boot from CD can do the job.BIOS i think its working fine.
  • dafuzz264 Dec 31, 2008
    Similar problem, only no Vista and XP Home edition and a DELL Deminsion XPS desktop. XP Install freezes at the screen that wants you to select install repair or exit. Replaced bad 120 gb hard drive with WD 500 gb hard drive. Any suggestions?
  • 55 Answers
Hii :
sir You installed correctly .. !!
You can install Windows Vista instead of Windows earning and easily
Just include the CD and follow the steps mentioned in the guide
Posted on Aug 22, 2008
    Sergeant:
    Novelist:
  • 166 Answers
Ok firstly, you will need to get rid of Vista all together before you can Install XP, Use a partition program to do this, You can find a bunch just by typing partition software into google, Delete the main partition that windows is on, Then create a new partition, then format that partition as a Primary partition, I always use the NTFS format just for stability and it can handle larger files than a 32 Bit partition, when you have done that then you need to get a bootable windows xp and I think you have that if set up is starting but hanging. Just go through the windows setup and you will be done. BE AWARE that you will loose everything thats on the drive by doing this so backup what you want to keep before you start, Always an idea to get the XP drivers for the system as well, The Vista drivers WILL NOT work on an XP system
Hope that helps.
If you run into problems then let me know and I will help you with it
  • 70 Answers
How far through the setup does it get?
Have you done a full format on the HDD?
Does the HDD detect in the BIOS? Is it a confirmed working drive.
I have a Dell Optiplex GX620 with a 64-bit Intel chip, and 6 GB of RAM, and I can't install any 64 bit versions of Windows on it.
your ram may be bad but not fried so windows cant deyect it also may need to reset your ram aet in advanced setting ,although your system sjhould detect that and adjust so check system in control; panel see if its is matchiing ie .. if u put 4 gb ram it may say 3gb ,if it has 4 gb then yiur settings systems icon control panel double click avanced system settings click on it then click on advaced scroll down to virtual memory it should be for 4 bg. ram would read 4000 MB OR REAL CLOSE TO ADJUST IT,, AL;SO U MUST HAVE 64 BIT OS XP AND REINSTALL OS PLUS PICK 64 BIT DRIVERS FROM MANUFACTER OF PC TO RUN 64 BIT CANT HAVE 1/2 AND 1/2 [32 +64] DONT MESH FOR 64BIT...32 CAN HAVE BOTH NOT 64
Jan 18, 2013 | Dell OptiPlex GX620 PC Desktop
Intergrated sound max not working
may be your computer have no proper sound drive so u must install your sound driver first after we can check the hardware error of your motherboard.. you can download driver from here http://www.getpcmemory.com/drivers/download-dell-optiplex-gx620-desktop-pc-windows-xp-vista-drivers/
Sep 05, 2011 | Dell OptiPlex GX620 PC Desktop
I have dell optiplex gx 620 with geniune windows xp .now i am getting message as counterfiet windows .how to fix
The validation files have been corrupted by a malware. Unless you have made a backup of them the only way to fix that is to save your personal files and reinstall XP.
Jan 04, 2011 | Dell OptiPlex GX620 PC Desktop
I'm trying to reset my system to the factory reset setting for the Dell OptiPlex? GX620
Bios or windows? If bios, go into bios by pressing delete key at computer boot up. Then go to last tab and look for load default settings. If you are referring to your operating system. Use your recovery disk or partition and reinstall the operating system. Or you can try Control Panel\Backup and Restore Center
Oct 23, 2010 | Dell OptiPlex GX620 PC Desktop
On my dell optiplex gx620 all of the usbs front and back dont work after the windows loading screen but power is working, usb light works. i dont no what to do i have enabled them in bios and default...
my dell optiplex gx620 is coming on but its not passing the bios revision or the boot up page i have tried every thing removing the small battery in the mother board unplugging the hard drive, i even busted the whole system and it still not coming on. i have triied sending it into safe mode and the 1234 light are comming on i have runed out of option and i dont know what to do.this all started 3 days when i turned off the computer tried to put it on but after it came on pass the boot up page the screen was blank
Oct 01, 2010 | Dell OptiPlex GX620 PC Desktop
Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
Jul 14, 2010 | Dell OptiPlex GX620 PC Desktop
OptiPlex 760 PC Desktop: Boots with this error: Windows could not start bec...
reinstall windows xp pro. in different folder
and keep all the files
May 18, 2010 | Dell OptiPlex 760 PC Desktop
Optiplex GX520 with vista
There should be no problem, if the sound doesn’t work try uninstalling the the Drivers and Reinstalling after you installed Vista im pretty sure that Vista will install the Drivers automatically.
Jun 01, 2009 | Dell OptiPlex GX520 PC Desktop
Dell optiplex g620
Check your BIOS. If it rebooted chances are it might work if you change the way the BIOS sees and boots the devices. Try rebooting without the flash drive in. What happens?
Please remember to rate my solution!
May 07, 2008 | Dell OptiPlex GX620 PC Desktop
Lost resolution windows vista upgrade on GX260
Hi all,
I tried numerous solutions for this issue and none of them worked except this one. I tested it with Vista Ultimate and don’t know if other Vista versions have the same drivers but here’s what worked for me:
1. Right click ‘Computer’ then left click ‘Properties’ to open up System window.
2. Click ‘Device Manager’
3. Click ‘+’ on ‘Display Adapters’ and you should see the drivers for your video. Right click and select ‘Update Driver Software...’
4. Select ‘Browse my computer for driver software’ and click ‘next’.
5. Click ‘Let me pick from a list of device drivers on my computer’
6. Untick ‘Show compatible hardware’
7. Select ‘Intel Corporation’ then select ‘Intel 82865G’. Click next.
This will install the drivers. No they are not the same drivers for the hardware but they work a treat!
May 05, 2008 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
319 people viewed this question
Alun Cox
