Could i get any assistance as when i try any of the techniques mentioned they all start with goto safe mode (and that directly gives me a login window again with no options) :( i have the latest updates for the idious XP.
This usually means you have a corrupt profile. I would log in using safe mode which might work. If you can get to the admin user in safe mode, use that to create a new profile. Otherwise you'll have to run scandisk. In Win XP, try this: http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix In Win 7, when you hit F8 to start in safe mode you can get to the prompt that says "repair my computer". Choose that option.
While
youforgotwindows
os password, you
canenter
safe mode (F8 when booting up) to recover
windows password while
you forgot
user account password, but
when you forgot adminpasswords,
there's
no way to change it, you should
use utility
to recover admin
password. Last
week, I forgot my Windows admin
password. Last,
I
used Windows Password Seeker to removethe
Windows password successfully. It's worth an
attempt. http://www.passwordseeker.com
Hi There,
Note: Below steps are for win 7, vista and if you are user any other operating system like win 10,win 8 then mention in next post.
The best and easy method I will suggest you to activate your windows hidden admin account and for that follow the below steps:-
Boot your computer into safe mode with networking
Shutdown the system>>press power button to reboot and immediately start pressing f8(for win7,vista)>>go to safe mode with command prompt>>run below command
Net user administrator /active:yes
Hit Enter and you should see a message that says, "The command completed successfully".
reboot to new admin account and copy your old your account data into admin account or create a new user admin account and copy data.
if this does not work than revert back, I will be happy to assist you.
You have not mentioned ur OS, any how for win XP follow the link below to download a free software to unlock ur win XP admin password. http://www.sharewareconnection.com/download-windows-xp-password-reset-software-from-sharecon.html Hope this will solve the problem
Reboot the computer. Press and hold the f8 button. Select safe mode from the menu. You should be able to see the admin login. Then you can make the changes.
some computers have safe mode accounts that run as admin that don't have a password try going into safe mode here are the steps to get into safe mode
one turn your computercompletely off
two turn your computer on and immediately hit F8 repeatedly till a menu shows the using the keyboard select safe mode
you should see a ***** of text go by don't worry this is normaly now the computer should go to the account's page select the administrator account and the computer should log you in fromhere goto the control panel and accounts page and ethere try to change the password on the old account or make a new admin account hope this helps
Following it
1> Restart machine
2> Press F8
3> Goto in safe mode
4> Select Admin a/c
5> If desk top is comming then
6>right click on my computer
7> go to manage
8> System tools >> local user and groups >user >select your name or account >right click >option would be com >set password >next >next > finish
9 >its ok
10> restart machine and check it
Log on to your computer with safe mode Steps 1. Start your computer 2. As soon as you see the first black screen when the computer starts , keep on pressing F8 You will see advanced options menu Select " Safe mode with net working" Now your computer will give you an option to log in with the administrator username You need to log in with Admin and then goto control panel and change the password for your username ...
If this does not work then plz reply back stating the Operating system you have like windows XP, vista , 98 , 2000 etc...
