Question about Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive
Acomdata external hard drive
I don't see a model number on this drive, but it is red. Really red. Anyway, I plugged it into my Dell Dimension 4500s using Windows XP and right off a little box at the bottom of the screen said that the new device was ready to rock, in so many words. The problem is, I don't see it anywhere when I go into My Computer. And I have no clue how to use it from this point. Thank you in advance for any help.And I have no idea what the model number is, but below it made me choose...so I picked the only one that said USB 2.0. It is really supposedly 130GBs and it's an external one at that.
  • 70 Answers
You won't see a new drive in My Computer until it's initialised.
Right click on My Computer
Click Manage
Select Disk Management (in the left pane)
Scroll down in the bottom right pane until you see your drive.
If you right click on the drive, you should have an option to initialise it. Follow the process through until the end.
Apologies for getting a little vague towards the end, I haven't initialised a drive in a little while now.
Hope this helps!
Posted on Aug 22, 2008
SOURCE:
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    Trouble with my Acomdata external hard drive and my mac
    Unfortunately it seems that Acomdata is no more on businness.
    In order to get support you can try writing an email to [email protected]
    Feb 04, 2013 | Acomdata Computers & Internet
    Do anyone have the sound drivers for yje dell dimension 4500s
    http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
    This is the support section of Dells website. You can enter your model number and they will have everything you need.
    Hope this helps!
    Oct 24, 2010 | Dell Dimension 4500S PC Desktop
    I want to restore factory settings on dell dimension 4500s desktop
    Format the hard drive and reinstall the OS with the Dell Restore disk. You will loose all data stored on the PC.
    Mar 12, 2010 | Dell Dimension 4500S PC Desktop
    Can someone tell me where to find a step by step procedure for replacing a hard drive in a Dell 4500s Dimension. I'm not talking about the physical part; that's simple. I need to know what I do step by...
    beware if you r trying to delete partitons coz you will loose all datas. better u take back up n try this method. rt. click on my computer then click manage there u select disk management where u will find ur partions dont do anything to c drive other drives can be deleted n created as per ur requirement. BE CAREFULL ALL UR DATA WILL BE LOST....
    Feb 17, 2010 | Dell Dimension 4500S PC Desktop
    Acomdata 1TB external drive
    I have the same exact drive (I'm assuming as it's the same make/size since I don't have a model number) and what you need to do is turn the drive off and let it cool down. The drive is not well vented and it tends to over heat. I would get in the habit of turning the drive off whenever you're not using it because of this problem.
    Sep 25, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
    I lost the power cord to my external hard drive.
    Hi annabel_nyc,
    You need to make sure that you get a compatible power adapter for that model. Most of Acomdata external drives use a 12v adapter, but not all. If you plug the wrong voltage into the drive, you do have the possiblity of frying your external. I'd check with your manual or post back your model number so I can look that adapter up.
    Good Luck
    Mark
    Aug 30, 2009 | Acomdata Computers & Internet
    Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive Logo
    73 people viewed this question
    Top Acomdata Computers & Internet Experts
    Ekse
    Joe Goldman
    Joe Goldman
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
