While trying to install my printer I ran into some problems with the print spooler, while trying to fix this problem I get this message displayed RUNDLL Erro loading C:\Windows\System32\xmqlllnu.dll The specified module could not be found I am using windows xp
    Master:
  • 788 Answers
That dll name does not even show up on Google. Your system is trying to tell you that the xmqlllnu.dll file does not exist. To a search on your system to see if you can find a copy somewhere to put it in system32
Posted on Aug 22, 2008
  • 70 Answers
What brand printer is it?
I've researched the .dll file and can't find any information on it.
    Sergeant:
    Novelist:
  • 166 Answers
I had a look at dllfiles.com and it doesnt list ur missing dll.
I would suggest getting the latest drivers for your printer, uninstalling the old ones and install the printer again.
If your print spooler is disabled then you might have issues as well. Just make sure the spooler is enabled. Click run then type msconfig and hit enter, under the serices tab make sure that print spooler is checked, spoolsv.exe is the command.
But firstly fix the drivers for the printer cause that looks like a service specific dll thats missing for the printer
Hope that helps
Let me know
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
I do not seem to be able to print any documents even after uninstalling old drivers and installing new ones what is wrong
Print spooler is no less than the chief boss of printing action. Print spooler is a linking part between your PC and printing hardware. Print spooler is the only master of print department of your PC office. Print spooler is a master of all printing procedurees and it’s that what is responsible for the redress printing queue and serial printing of your documents. Any messages like “Spooler subsystem app has encountered” and “Spooler subsystem app stopped working” are a unfavourable sign that you have met printer problems and need facilitate. Spooler virus is not so wide spread but it can be a reason of printer spooler service keeps stopping. If printer spooler keeps stopping our tool is a best thing to sort it out.
Fortunately I know the program which can help you to eliminate print spooler virus without extra efforts. I see Print Spooler Fix Wizard as an optimal medicine for print spoolerWhen the whole province stopped because of corrupted print spooler function it’s significant to discover an trouble as soon as possible. Don’t wait a wonder from your printer – it’s nothing without its print spooler. It’s not required to find another place to copy any documents because you can cure your own printer with the assist of Printer Spooler Fix Wizard for five minutes.
Printer problems: is it an boring chance or a reason of why the whole department interrupts its earn money? When you end your earn money sending a paper into your printing waiting line print spooler only begins its earn money. Are you really sure that high-effectively your print spooler will ever hold out against print spooler virus? You needn’t activate to buy a up-to-date printer if you have Printer Spooler Fix Wizard. So fast and effectual treatment as Spooler Fix Wizard may become a salvation of your province printing capabilities. Just as you need your printer earn moneys now and printing tasks can’t be call off we suggest you Printer Spooler Fix Wizard.
You have a choice: try perennially to cure your print spooler by yourself or get Print Spooler Fix Wizard last and all the time. Doesn’t an hour of your work cost less than Print Spooler Fix Wizard? It’s better to get high effective solution for several minutes than try to cope with printer problems manually. When you choose Print Spooler Fix Wizard you decide successful help.
All the best Pineworks
Apr 24, 2010 | Lexmark X1270 All-In-One InkJet Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Printer Spooler service!
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
Jul 27, 2008 | Lexmark Z645 InkJet Photo Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
