Question about Whirlpool LSR6332K Top Load Washer
Cold water won't stop
Machine on or off the cold water will run continuously. I need to know how to fix before I have another mess in the laundry room. Thank you for your help...
  • Kevin Richardson Aug 22, 2008
    Yes,very much, Thanks for the fast answer
    President:
  • 1,450 Answers
There is solenoids on the inlet where hoses hook up the cold water one is probably stuck. Or the fill switch is defective.Most like;ly a stuck solenoid. does it slow down at all? when full
Posted on Aug 22, 2008
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
That is what I wondering. I leave the door open and have noticed there will be water in my washing machine. It wasn't there when I removed my laundry. It doesn't happen all the time. I can't find a...
Hi you have a faulty water valve that is allowing water to weep past. if the machine is hot and cold fill. turn off the hot water tap. the machine will still work with cold water only. if it stops the weeping through you know the hot valve is faulty if it does not the cold valve is faulty. just replace whichever is the culprit.
Jan 20, 2011 | Washing Machines
I have been delivered a Aquiras Extra WMA 40 but I only have a cold pipe but I notice the machine has a hot and cold pipes do I connect to just the cold pipe and will the machine heat the water inside
No, the machine does not have a heater unless it has a sanitizing cycle which heats already hot water even hotter.
For the machine to work as advertised, you'll need hot and cold water connections. However, if you just hookup the cold water and run the machine on its cold-water setting it will wash -- the laundry may not be as clean as you would like in some cases, but the machine will operate properly.
Charlie
Jan 06, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Cold water fills the tub even when machine is not
This is almost definatley the inlet valve faulty.The inlet valve is literally stuck in the open position.You will need to change the inlet valve.I hope this helped you.
Jun 01, 2010 | Washing Machines
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Just finished a load of laundry and the machine smelled hot plus there was still soap in the machine. It finished its cycle but I had to rinse the clothes by hand to get all of the soap out.
I don't know if it has been considered, but I would look at a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the openings on the water inlet valve (especially the cold water side). Make sure they are clean of rust or debris. Next, check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 08, 2009 | Whirlpool LSB6000PQ Top Load Washer
Cold water wash and rinse not working.
check the screens on the water inlet valve and or replace the valve
May 19, 2009 | Admiral AW22 Top Load Washer
Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Apr 08, 2009 | GE WJSR2070B Top Load Washer
Ge washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | Whirlpool GST9679P Top Load Washer
Whirlpool LSR6332K Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
