Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice dispenser not dispensing.
Whirpool side by side refrigerator with fast fill water dispenser, model no above; just turned a year old, so out of warranty. Ice dispenser will not work on crushed or cubed selection. Have confirmed not locked, have emptied and thawed out ice bin. When button pushed to dispense either crushed or cubed ice there is a slight grinding noise - then nothing. Thought I would try a hair dryer today on the motor, see if maybe it is just frozen.
  • Anonymous Aug 31, 2008
    I have the same exact problem. I unscrewed the two screws showing when you remove the ice bin. That was a mistake but when you remove the two screws that are underneath the area and then remove the plastic plate you can reach two more hex screws inside that hold the motor. that might be a mistake as well because i think we are really trying to find the switch that is bad and not the motor. I need to find a hex wrench that fits this small hex nut
  • nayyar72 Sep 03, 2008
    i've got the same problem. when I remove the bin and check the motor speed, it appears slow and not a smooth motion. Is this what you see?
  • 61 Answers
The hex wrench your after is know as nut ddriver screw drivers / you can remove the auger assembly quite easily the activation switch is located in the door assemby. be carefull the auger is powerfull.
Posted on Oct 06, 2008
I have a water/ice dispencer in the door of a side by side Whirpool model no. GS2SHEXNT00. The water dispenser leaks, sometimes a large run of water other times just a drop. I took the front cover off the...
Heat from the night light will deteriorate the plastic tubing of the dispenser. Cracks in the tube will allow water to go out the side of the tube as well as in the glass you're filling. There are repair kits available from online appliance parts companys.
Apr 10, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
My Whirpool ref. stop making ice. There is water
feed valve most likelly cause remove wtr. line if water comes out water valve is somthing to look at if it has power
Jan 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
WHIRPOOL ED2
Not enough model to get the wire diagram. It sounds like a diode is out in the water valve harness. If it is using the triple valve on that unit.
May 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
332 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
