Question about Whirlpool Refrigerators
Whirlpool side by side refridgerator model GS6SHE*N*O, icemaker won't produce ice. Watter line is okay. This is only 6 months old.
  • scottgearig Aug 22, 2008
    It is not new. It was working fine, but not now.
    Thanks, I'll try that.
  • 594 Answers
Make sure your ice maker is turned on and if it is a new install than it will take about 24 hours for the first bin of ice witch you will need o throw away because it is like the first snow the first ice that comes out will have the dirt and things that are in the line.filter and ice maker.
Posted on Aug 22, 2008
  • Cameron Viseth
    Cameron Viseth Aug 22, 2008
    shut the ice maker off. the unit it's self should come out for cleaning. take it out and make sure there isn't any ice blocking the flow of new ice if it is made.
Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
Whirlpool Gold refrigerator is not making ice. Just stopped 3 days ago for no apparent reason. Fridge is 6 months old.
as long as the fridge is working properly the only thing that it could be would be the icemaker...the fridge should still be under factory warranty if it's 6 months old so they should cover it
Oct 03, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Model#ED5VHGXML10 Whirlpool side by side refridge. I took the Ice tray out and dumped it into my cooler and replaced the tray and the ice never produced again. Every now and then, I can hear...
check to see that the fill tube going into the icemaker is not frozen, if so thaw it out with a hair dryer and you should be in buisness
Apr 09, 2008 | Refrigerators
Refrigerators Logo
169 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
