Question about Whirlpool Refrigerators
Whirlpool refrigerator makes a clicking sound like it's trying to turn on. Happens over and over but the motor does not start. Refrigerator is not producing any cold. What is the problem and the potential solution? Please respond ASAP by return email to [email protected] or call 315-729-7585
  • Anonymous Sep 14, 2008
    I have the same problem. The tank is very hot to the touch. What do I do?
    President:
  • 1,462 Answers
Probably a compressor fault - the clicking noise you hear is the start relay trying
Posted on Aug 22, 2008
6ya staff
SOURCE:
I have a 2004 Whirlpool gold model #GD5RHA 25.4 CF refrigerator. It has stopped cooling (both freezer and refrigerator). The evaporator fan inside the freezer operates but the evaporator coil are not
go to a refrigeration supplier and buy a 3 in 1 kit meaning relay, capacitor and overload in one unit just follow the print in the unit and it should start after you plug it back to the wall make sure you disconnect before working on this unit let me know what happens. nice picture and very helpful for me.
Dec 31, 2014 | Whirlpool Refrigerators
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Refrigerators
My fridgidaire makes an odd sound in the back as if a fan blade is hitting something. It happens periodically, not continuous. What can I try to fix this? Is it as simple as removing a cover to clean...
The bearings are going bad on the fan motor and that lets the blades move too much and they hit...you will need to replace the fan motor.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 29, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator won't get cold
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
MY SXS FRIDGE(MODEL # GD5THGXKS03) HAS STOPPED COOLING ON BOTH SIDES. THE MOTOR IS RUNNING, AIR IS BLOWING(NOT HOT, BUT OT COLD EITHER) I VACUUMED OUT THE UNDERSIDE HOPING THAT THE BUILD UP MAY HAVE BEEN...
If your model has a start-capacitor on the compressor, that is the problem. When the switch energizes the compressor, the start cap provides extra current (technically phase-angle correction) to start the motor.
If the motor start cap is bad, the current-limit switch which is typically on the back of the compressor, opens up to prevent over-current condition.
So the switch tries to start, but with a bad cap, there's too much current, so it goes click-click, click-click, and the compressor never starts.
This happens all the time on old freezers, as well as on electric dryers.
Oct 16, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool
How to check stuff>
Oct 03, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Very loud noise whirling sound
Can you tell me where the sound is coming from? Like inside freezer or under refrigerator. Most sounds like you describe come from a fan motor and the fan blades are hitting something. Let me know, Thanks, Sea Breeze
Apr 23, 2009 | Whirlpool ED5FTGX Side by Side...
Our Whirlpool SVF15NRHW01 does not defrost it just ices up
Your refrigerator has a defrost timer and this could be the problem. It appears to be inside the refrigerator. Locate and try to turn the timer slowly clockwise until it clicks and compressor stops. The refrigerator should remain off for 20 to 30 minutes and the freezer heating element should come on. The sound of crackling in freezer indicates ice cracking and beginning to melt. Let me know what happens, Thanks, Sea breeze.
Mar 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Side by Side Fridge Not Cooling
Here's the sequence: First, the unit must be ice free. This happens after power down for about 2 days. If the compressor is clicking, power off for 15 minutes. While waiting....
Clean the condenser coils.
If a mechanical thermostat, does it click when you turn it from off?
Locate compressor in back of unit. Find largest pipe. Power on.
Pipe should frost over for about a minute and then either dry out or form ice on it. If frost stays, you need refrigerant.
If compressor is not running, it could be thermostat, defrost timer (find this little gem in the back of the refrigerator and turn the stub shaft about 1/3 way around...does this change anything?) If the timer is bad...replace it.
Compressors generally don't fail from long run cycles.
hope all this gets you somewhere.
Nov 18, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
585 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
