Question about HP Office Equipment & Supplies
I will be going on an extended vacation ,approx 5 weeks, and would like to know what to do to my HP DeskjetD2460 Printer so the nozzles will not clog up when I am gone. Thank you for your help. Bill
  • 48 Answers
Remove the ink cartridges from the printer, place it on a ziplock bag, store them in a dry area.. put the printer in its box...
Posted on Aug 22, 2008
How do I clean the printhead on my HP 2410 Printer?
every printer has a tool installed on the computer called clean heads. or something like that.
Run a cleaning cycle and do a head aligning, just to see if all nozzles are working.
When you have the printer working, please once a week switch it on and switch it off after say 5 minutes, just to clean the heads once a week. Just to avoid clothing of the nozzles.
Apr 19, 2015 | HP PhotoSmart Office Equipment & Supplies
What is the cause of new cartridges running out of ink while checking trying to align print head?
You must replace the print head., as long as printer detecting that nozzles are not firing properly., it keep on cleaning the head, result it will drains the inks from the ink tanks...once you replaced both print head & tanks, take print outs at least twice in a week., perform nozzle cleaning once in a month to avoid this type of nonsense..
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
Epson printer partially printing
Sounds as though you have blocked nozzles - perhaps through leaving printer, especially in a dry atmosphere? Try going into the Printer's Properties dialogue box and then the Advanced tab to then use the Nozzle Clean routine. Ensure you always do a Nozzle Check after every cleaning cycle. That will improve the ink flow - should you have any still even slightly clogged - obtain some Ammonia - 5% solution is fine (some window cleaners have this - Windex with Ammonia in many countries - Ammonia of course will be a bit cheaper. To make a 5% solution (approx.) put a teaspoon into a cup of water. Make a pad of some linen say 4 layers (like a handkerchief as example) of about 6" x2". Set the printer into its Cartridge Changing mode - it will move the printhead. Then disconnect the power lead (NOT turn off or head will re-park). You can then freely move head so put soaked pad in well and move head until across pad so nozzles can soak up. Leave for a couple of hours. Slide head off and remove (now ink stained) pad. Just plug power back in and switch on (some Epsons will auto restart when power replaced - you may have to switch yours on). It will re-park head after doing a clean. Then do a nozzle check and should be fine.
Mar 21, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Clogged ink nozzles
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jul 09, 2012 | HP Photosmart D5069 InkJet Printer
Hp 8500 printer stuck in continuous cleaning and alignment loop after replacing cartridge
Printer wont do the alignment process if we replaced the cartridges, might be removed/re inserted the printer heads, then ply it process the alignment, if the print head nozzles are clogged, alignment process wont completes..
>Remove the print heads clean the nozzles with tissue paper gently at nozzles.
>borwse this link & see how to clean the print head,link:http://www.youtube.com/watch?v=ZAwYIbjswV0&feature=related
>Install the printer heads do the alignment..
> if not completed check which printer head clogged, replace the print head.
Oct 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Hi i am not able to print in color, even though my settings are to print in color and the cartridge is nearly full. I have an all in one printer HP FA2480
Pls reset your printer.
1.Switch the Printer ON by pressing the Power Button (Make Sure Paper is not Loaded)
2.Once switched on, hold down the Power Button (DO NOT RELEASE)
3. Now press the Cancel Button and let go of it
4. Now Release the Power Button
5. Wait...
6.The INK LED will light up,
7. After a while it will attempt to print a sheet but because there is no paper the resume button will blink
Now press cancel
You have completed the steps and now should be able to print if not attempt this again from STEPS 1-7
Feb 09, 2011 | HP DeskJet F4280 All In One Printer InkJet
I had low ink and changed the ink cartage but i still can not print. also a light is flashing it looks like a tear drop. this is on a HP Deskjet D2545
Go in to your HP solutions center and click maintenance. Click on clean printer nozzles. If the printer was low for a while the nozzles may be clogged with dried up ink.
Jan 01, 2011 | HP Deskjet D2545 InkJet Printer
5740 acts like it's printing, but no ink on paper
Since it's trying to print, the printer probably just needs cartridges. The ink can dry in the nozzles with age and disuse and clog them.
Before you splurge on new cartridges, try getting them going. (This assumes there is some ink left in them.) Take the cartridges out of the printer, wet a layer of paper towels about 1/8 inch thick, and whack the nozzles against the wet surface a few times. Check every few whacks to see if you're getting any ink flow. Repeat until you see some ink on the towels and on the nozzles, or until you decide it's futile. Often this dislodges the clogged ink and opens the nozzles, and buys some extra printing time. But you're probably going to want new ones soon anyway.
Apr 08, 2010 | HP Deskjet 5740 InkJet Printer
Prints in only one color
try this solution:
1. clean the tab circuit of your cartridge (if the cartridge is not empty)
2.wipe the head of the cartridge containing nozzles on a wet cloth(to remove clogs covering the nozzles)
3.if the cartridge have a low ink pls refill or replace a new one.
4. perform a maintenance forge to the heads,
5.print a maintenance page.
thanks for using fixya..
pls let me know if the problem still exist.
Nov 30, 2009 | HP Officejet 4110 All-In-One InkJet...
Never used for one year more,what will happen it?
Well,inkjet printer;no matter what brand is will suffer ink clogging if you never use it for long time. Ink clogging may occur in print head (cartridge nozzle) or pump nozzle. So,ink cannot flows properly. You can try perform printhead cleaning when you use it again but if it doesn't help you should replace those parts. For inkjet printer it's strongly recommended that you turn on your printer at least once a week to clear all ink nozzle.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
