Question about Toshiba 42HP95 Television
HDTV Format 720p is a supported format on the 42HP95 per owners manual and specification list.
    New Friend:
  • 68 Answers
Please clarify your question/statement.
Posted on Sep 10, 2008
Need a users manual sanyo dp19649
Typed "sanyo dp19649 manual" into Google, this is what came up on the first result:
http://us.sanyo.com/LCD-Televisions/720p-18-5-LCD-HDTV
below the picture of the TV there are 3 tabs, you want the "downloads" tab. There you can download the Owner's Manual in PDF format.
Apr 03, 2011 | Televison & Video
Thompson DVD DTH271E refuses to play HD DVDs but fine normal DVDS, cant seem to get any help via Thompson, & think may need "firmfare" update? New machine but in Spain & language...
Hello there.
Push "Play/Pause" and "DVD Rec" on the dvd recorder a few seconds to see the service menu. There you can find your firmware version.
Post back the version for us.
Hope this helps.
May 06, 2008 | Televison & Video
Tip
Toshiba 42HP95 Manual Download
Download Toshiba 42HP95 Plasma TV Manual
Would you like to review the features of the Toshiba 42HP95 Plasma TV ?
Have you lost your Toshiba 42HP95 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 42HP95 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 42HP95 Plasma TV documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Can i watch windows media files on my ipod touch 8 gig?
Apple's iPod Touch does not support Windows Media Files. You will have to convert the files to a compatible format.
Support Media Formats (located at http://www.apple.com/ipodtouch/specs.html)
  • Audio: AAC (8 to 320 Kbps), Protected AAC (from iTunes Store), HE-AAC, MP3 (8 to 320 Kbps), MP3 VBR, Audible (formats 2, 3, 4, Audible Enhanced Audio, AAX, and AAX+), Apple Lossless, AIFF, and WAV
  • Video: H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format; Support for 1024 by 768 pixels with Dock Connector to VGA Adapter; 576p and 480p with Apple Component AV Cable; 576i and 480i with Apple Composite AV Cable (cables sold separately)
Feb 09, 2011 | Apple iPod touch
Insignia 32" 720p Flat-Panel LCD HDTV - High-Gloss Black Picture is too big for screen ,cut off all around, top, bottom and sides. Can't read things on screen, heads cut off etc. I've gone through...
try checking the menu setting on your Dish Network, there may be a television format in that menu set up, if it is only when a dvd player is playing, then check the format on that, so on so forth... that is one place to start, check if it is local (TV) or if it is from attached component ( Dish dvr/ dvd etc). also refer to your owner's manual.. if all else fails, call customer service @ insignia
Oct 17, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
There is no picture and it shuts down and then tries to restart
Your set is not receiving a valid signal for the resolution of the set and shuts down as a self-protective measure
so you have to make sure the source is sending what the set needs and then it will show a picture at the
acceptable resolution.
Do you know the range of resolutions allowed with your set?
They are:
Broadcast Format Displayed: 720p (HDTV) · 480p (EDTV) · 480i (SDTV) Broadcast Format Supported: 720p (HDTV) Digital TV Standard: HDTV - HDTV receiver is integrated. Built-in Tuner: NTSC Aspect Ratio: 16:9 · 14:9
Apr 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
I'm getting an invalid format on my hdmi inputs when i hook up my ps3. It's wierd because it works on my viszo, but not on my new westinghouse or my samsung.
If you accidentally set your PS 3 for 1080p resolution, when the TV can only support 720p, you get a black screen. The Westinghouse TV I used displayed a message that said "invalid format." To reset the PS 3 to the standard AV format, you shut the PS 3 off. Then you hold the PS 3’s power button down for about 10 seconds. It will reset to standard video
Dec 27, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Picture format ?
This tv maxes out at 1080i, but that is for the HDMI input. 720p for the Component video input.
Feb 02, 2008 | Philips 30PW8420 TV
Televison & Video Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
