Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Green is gone on Sony
Did that solution work...I am having the same issue.
  • 790 Answers
Hi
You Have defective RGB, the RED, GREEN, BLUE. you have defective green circuit, maybe you have defectice transistor driver for the green cathode..
Thanks!
Posted on Sep 19, 2008
Sony KDL-46S4100 no picture, no audio but the green power button works
Hi there , this may or may not help but i have a sony model KLV 46X200A i had the same fault only green led going and you could hear the sound of a relay click nothing more , to cut a long story short the TCON board was faulty , as it was hard to get hold of a replacement , i found that a very small fuse on this board had gone open so replace this fuse with 1 from a laptop backlight board , the tv now works fine , i hope this helps .
Apr 23, 2015 | Sony Televison & Video
My 60 inch Sony flat screen has a green color to everything. I have replaced the lamp.
Hello.
Unfortunately most expensive part in your TV - optics block - is gone bad. Sony issued recall that is already expired for most of the models. I would still recommend you to contact Sony and figure out if you still covered under recall. If not - repair might cost somewhere in $800+ range.
Sorry for bringing bad news.
Maybe it's a time for new TV.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Tv gone green/blue and sometimes red in top right corner
If you have a Sony rear projection LCD TV then you have a failing optics block. LCD TV's are not affected by external magnets like CRT TV's were. The optics block issue will only get worse and needs to be repaired by a technician.
Sep 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
My CRT TV has false colours.
The set needs degaussed this is common issue, most tv's have a degaussing coil in them, but they are very weak and will not correct extreme issues. It is possible the internal degaussing coil has stopped functioning. If this is one of these sony 40" crt's this is a big problem. and any metal near by will cause gausing of these tubes. Have a tech come out and degause your tube. A technician will have a very powerful loop coil that will clear the problem with one or two passes. But if it returns, check for perminant magnets near the set like large speakers or any other thing, this can also be caused by a child;s toy with a magnet it it if the child has rubbed it across the screen. This is not a destating issue and can be corrected easly.
Aug 30, 2009 | Sony KP-57WV600 57" Rear Projection...
Green screen projection
This is the exact same issue as I described for an Epson user. So I'll repeat it here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the green color has gone out. The image is made up of red, green and blue images layered upon the screen. If the green panel has gone out then there is nothing filtering out the green light in the image. This causes a nice green hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Sony Office Equipment & Supplies
Sony KV-32FV27 ...no Green?
HI
You have defective RGB Circuit, Check the green Gun Cathode path, maybe you have open resistor or open driver transistor. or open Variable resistor.
Thanks!
Nov 28, 2008 | Sony KV-32FV27 32" TV
Bright green flash and red arching lines
You need to check the bulb in the back of the set as it could be on the way out . just check to see if the bar in the bulb has gone black as it is a good sign the bulb is on it's way out . the bulbs only last 2-3 years or 4000 hours . If thats ok you most probaly have dry joints on the tuner , they just need resoldering
Jan 29, 2008 | Sony KP-46WT500 46" Rear Projection...
SONY KV2565AS
There are 4 trnsistors,4 resistors, they're alike in size and value on a small board attached to the neck of the tube check them out and caps too.
Aug 21, 2006 | Sony KV-32S26 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
