Question about Mitsubishi VS-50607 50" Rear Projection Television
Rolling screen any way to stop the pic from rolling up and down Our TV is actually a Mitsubishi VS-50607 and the same thing, rolling screen and when it isn't rolling there are lines that go across it. Once the tv warms up they go away and you would never know anyting was wrong with it.
  • Anonymous Jan 03, 2009
  • Anonymous Feb 03, 2009
    I have the same problem......does anyone have a solution or any info on what causes the tv to do this?
My screen on my mitsubishi won't stop rolling
Posted on Oct 29, 2008
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Vs-45607 was a hand me down and did not come with a remote. the picture has very fast rolling vertical lines........Help!
Typically you can open the back case and you will see two screws, one for vertical scroll and one for horizontal scroll. with a rubber head flat head you can adjust this. Please be advised this is very dangerous and has high voltage. Please get a tech to look at this, he must be familiar with this TV.
Sep 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I don't know how to get to the mirror and projection guns
the front trim on the tv pops off...there are screws all the way around the screen that you have to take out to remove he screen to get to the tubes and the mirror. once you pop the trim off youll see how easy the rest of it is
Feb 21, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi 50607
22 is the code for short protection. Which means the set has shot down due to one of the components being shorted. My quess would be at least a 3 to 4 hundred dollar repair maybe more depending on the shops integrity.
May 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
TV shutdown for roughly 10 - 15 minutes after being on for hours
Yes the vertical circuit will shutdown the set if theres a problem with the deflection circuit. This model has a history of leaking CRT coolant on the boards near the vertical IC destroying the solder and actually eating through the circuit board. Check the area near the Vertical output IC for signs of coolant leakage or solder cracks.
Mar 11, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 has Jitter at top of picture- intermitant
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 14, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Oct 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS50607 Self Diagnosis 2-3
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Oct 21, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Locked up
I have a VS 50607. My manual gives instructions that may work for your set. See the attached pic.0fa93b0.jpg
Aug 02, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
520 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
