Question about Ovens
Stoves model number 059040404
Grill has packed up. Need new printed circuit board or is it the door micro switch? urgent, please we run a hotel and need our grill
URGENT URGENT URGENT
    President:
  • 1,462 Answers
Try the simple things first. check continuity thro the grill element - likely the element is open circuit
Posted on Aug 22, 2008
SOURCE:
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Need switch for stove model 720ef that when turned anti clockwise puts on half off grill and when turned clockwise puts on the whole grill where can i buy one
Sounds like maybe u just need the knob.u can call repair clinic the number is 1866-822-0890 or 1-800-269-2609 they of most parts on hand .I order my parts first day and alwas get them the next day .
Nov 09, 2011 | Ovens
Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the...
First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
All the best
Jul 26, 2011 | Stoves 720EF Electric Double Oven
The oven and grill when in use switch themselves off after a while. They will switch themselves back on after a while.
It could be the thermal cutouts operating. First things first, is the cooling fan running and does it turn off about 10 mins after the ovens/grill are turned off? If it isn't running then the unit is overheating and the thermal cutouts will operate. If it is running normally, then the cutout could be switching in early due to them becoming old and ineffective. There are two cutouts in the oven. One controls the main oven and the other controls the top oven. However, the grill operates without the clock being set, i.e. it is independent of the clock. So, if both the top oven and grill stop working together, according to the wiring diagrams in the handbook, the only thing it could be is the thermal cutout for the top unit.
F.Y.I. The top oven switch controls both the grill and the oven elements. In other words, in its OFF position, the Grill works and the Oven doesn't and in its ON setting the Oven works and the Grill doesn't. However, I can't see this failing as you specify, but worth checking if you take the oven to bits. The Grill will only work if the oven door is down.
If you need to replace the cooling fan, you will have to take the whole unit out of the kitchen cupboard to gain access to the top and rear oven panels, which have to be removed to gain access to the cooling fan and wiring. If you do replace it, ensure all the vents for air circulation are free from dirt and grease before you put it all back.
Try espares for STOVES spares. If the item is not listed you can ask them for a quote.
Be aware that the cooling fan is controlled by a timer circuit board and an in-line resistor on the fan terminal block. Either or both of these two and or the fan could have failed if the fan is not running! Any competent electrician should be able to work out what has failed.
All the diagrams are in the Handbook. If you need a copy, supply an email address and I will send you a pdf copy.
If you do ask for a quote, I suggest you ask for prices for all the parts mentioned above, so once you have checked what has failed, you will have enough info on pricing and availability as to whether to proceed or not.
Jan 18, 2011 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
No Grill operation for stoves 720ef
Supply an email address for you and I will grant you access to my BT Digital Vault where a copy of the complete handbook is lodged. It includes circuit diagrams.
With your fault, can you here the switch operating, if not it just may be stuck?
Dec 12, 2009 | Stoves 720EF Electric Double Oven
Ovens Logo
135 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
