Question about Northgate (STAX2517C2) PC Desktop
Box pop up
It says Stackoverflow@line:270
  • 166 Answers
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines.
Basically you have a specific program causing the overflow or a hardware conflict (usually a driver error). find out what the program is, and depending on what it is, see if there is an update on the vendors website (usually if you are getting the error someone else has had the same problem)
Have you just installed a program or a new piece of hardware?
Microsoft has a support doc available that will explain more to you.
Let me know if this helps or if you require further assistance
Hope that helps
Posted on Aug 22, 2008
I have a winchester ranger 270 cal. Rifle . Was wonde ring what model it is .... the serial number is G1871685
  • Winchester Model 70 - Wikipedia, the free encyclopedia ... 6.5×55mm, .264 Winchester Magnum, .270 Winchester, ... 70 Winchester rifles is the serial number ... the Winchester Model 70 rifle and Winchester Model ...
  • What is the value of Winchester ranger 270 caliber Serial? > ... > Firearms > Winchester Firearms Answer The Winchester 270 .22 was first introduced in 1963. It is not a collector item, or "rare". It is however a very good .22 rifle which should be enjoyed as ...
  • .270 Winchester - Wikipedia, the free encyclopedia Large rifle: Maximum pressure: 65,000 psi (450 MPa) Ballistic performance; Bullet weight/type Velocity Energy; ... The .270 Winchester (or 6.9x64mm) ...
  • winchester ranger .270 - Shooters Forum
    • 16 POSTS
    • FIRST POST: 2006-07-18
    2006-07-24 · Shooters Forum > Rifle and Rifle Cartridges > Rifles and Rifle Cartridges: winchester ranger .270 ... Winchester. Think push-feed M70 serial ... Ranger" mean? Caliber ...
  • What Is The Value Of A Winchester, Model 70, Cal. 270 ... What is the value of a Winchester, Model 70, Cal. 270 ... of a Winchester, Model 70, Cal. 270 rifle. Serial number ... a Winchester model 70 270 cal the serial ...
  • 575 - Winchester Ranger .270 cal bolt-action rifle. Only ... > Firearms & Military Artifacts 575 - Winchester Ranger .270 cal bolt-action rifle. Only fired off one box of ammo.
  • Ranger T - Winchester LE Ranger; T-Series; T-Series. When a ... Winchester T Series is ammunition that always performs at its best-even when things are at their worst. ... Rifle Ammunition ...
  • Winchester Ranger (M70?) .270 Win ' Gun Values Board I have a Winchester Ranger Serial # 5352836, 30-30 cal. Has a ... Tips for finding accurate ammunition for a .270 Win. chambered rifle. ... 1985 Winchester Ranger ...
  • Is a Winchester Ranger 270 cal a long action rifle? - Answers > Categories > Hobbies & Collectibles > Firearms Is a Winchester Ranger 270 cal a long ... What will excite ANSWERS.COM users for them to go ... The .270 Winchester is a great rifle for medium sized game such as ...
  • 270 Winchester Caliber Rifles for Sale - Online Gun Store ... > ... > Firearms > Rifles > Shop by Rifle Caliber We carry 270 WINCHESTER caliber rifles for sale in our online gun shop, including hunting rifles, tactical rifles, and more. We stock Browning BLR rifles, Remington ...
  • May 01, 2016 | Optics
    Willtab, You are the man! I printed out your instructions. Went to RadioShack...
    FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
    TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
    2. Remove the back. there a number of torx 20 screws.
    3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
    4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
    5 when you get the tray up the bottom side of the board can be accessed
    you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
    7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
    8 reassemble set. make sure you examine the set for loose connections.
    9 and remember "BE Careful'
    on Nov 07, 2009 | RCA R52WH73 Projection Television
    Windows 7 toshiba laptop tells me dns down
    it should be dhcp, click the box that says automatic, if there's something wrong with your ISP's DNS server you can manually set it to and which are google's DNS servers
    Dec 13, 2013 | Toshiba Satellite A100-S8111TD Notebook
    Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
    Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - If not, you can also send them your question directly so they can help you resolve the issue.
    Jan 27, 2011 | Office Equipment & Supplies
    Hi I have broken the lid on my necchi 270
    You will have to contact a Necchi dealer to see if this is available.
    To locate your nearest Necchi Dealer us at 1-800-525-9987 ext. 4
    Mar 01, 2010 | Necchi Sewing Machines
    I heard a pop and then i saw sparks inside the oven, the sparks were coming from what looks and feels like a paper cover inside the microwave
    This sounds like the inner lining is coming off and alloying the metal interior to spark. You will need to repair the liner and this should fix your problem.
    Dec 08, 2009 | DCS MO-24-SS Microwave Oven
    1600h same problem with ingiter
    It is a control box issue but now I have to decide if I want to spend $270 to fix or for $299 buy a regular water heater. By my calculations being this is year three, the 15 year life expectancy of this 1600h water heater will cost me $1500 in parts alone.
    Sep 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
    My Mercedes ML 270 cdi ABS etc lights and gearbox.
    • you need a Brake safety switch replaced.This is located behind you brake's a common problem. The warning lights will reset after a few engine starts.
    May 18, 2009 | 2002 Mercedes-Benz M-Class
    Northgate (STAX2517C2) PC Desktop Logo
    153 people viewed this question
    Top Northgate Computers & Internet Experts
    Lee Eismann
    Tom Chichester
    Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
