Question about Kodak EasyShare C360 Digital Camera
"Memory card cannot be read"
The camera screen displays the message "Memory card cannot be read (please format card or insert another card)." What should I do?
My camera used to do the same thing--once I got the pictures off my card, I left it in the card reader, right clicked on removable media (my computer + removable storage) chose to "format" and formatted it on my computer. It seems to have fixed the problem, and my camera now reads it fine. I tried to format it on the camera before, but it didnt work.
Posted on Jun 02, 2008
    Scholar:
  • 114 Answers
The memory card is corrupt or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Posted on Aug 29, 2005
2 Suggested Answers
SOURCE:
  • 11967 Answers
SOURCE: C190 does not read the SD card even when SD card
Where are you formatting these cards? You're supposed to do them in the camera.
Posted on May 02, 2010
I have not used my Fuji Finepix 6800Zoom for many months so I charged it up and now when I turn it on 'ERR CARD' is displayed in the round screen. If I press Menu and then Back !card not...
May be you inserted a memory card formatted with your PC. Format the memory card using the Format function in the camera menu. Format function can be found in the setup menu of the camera.
If this does not work, try replacing the memory card.
Sep 02, 2011 | Fuji FinePix 6800 Zoom Digital Camera
I havea kodak M340 and just purchased a 8GB sdhc memory card. I keep getting a message memory card requires formatting. I press OK, get a message formatting ... and then back to the same message, memory...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Aug 18, 2010 | Kodak EasyShare C340 Digital Camera
C190 does not read the sd card even when sd card format is ok . it is giving a message 'memory card requires formatting' 'please format memory card or insert another card' however inserting a new...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 20, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    AIPTEK IS-DV2
    First check the memory card to see if the lock tab is in the UNLOCK position. On the top left of the memory card is a slide the moves up and down. The slide should be in the up position for it to be unlocked. A locked memory card could cause the camera to read a CARD PROTECT error message.
    If you still receive an error message, verify that you are inserting the card correctly so that the spring locks in as you fully insert it. When performed correctly an Icon will appear in the lower right hand corner of the LCD screen. Also try inserting the card while the camera is on.
    The memory card may also need to be formatted through the camera’s settings-- Note: Formatting will delete all files, so be sure to transfer any important files to your computer before doing so
    To Format: Insert the memory card into the camera and press the mode button to get to the mode screen. Enter into Tools/SETTINGS and find FORMAT. Once you select format you will receive a YES or NO option. Select YES and you will see a FORMATTING message. Once the formatting is complete, see if the camera reads the card and functions properly
    Jul 08, 2008 | Aiptek IS-DV2 Camcorder
    The camera screen displays a "Memory card requires formatting" error message. What should I do?
    This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
    Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
    "Read only card, change to internal memory to capture"
    This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    The camera screen displays error message
    Aug 29, 2005 | Kodak EasyShare One Digital Camera
    Kodak EasyShare C360 Digital Camera Logo
    342 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Parshiv Luthra
    Marvin
    Marvin
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
