Question about Sony KP-51HW40 51" Rear Projection Television
Green screen but pip has color
I've replace the main board due to tv repair person telling me that this why I had green. Prio to replacing the board still has pip color but green, now that boards replaced still the same. What can I do to fix my problem.
  • kevin0687 Aug 22, 2008
    The TV is 51HW57
  • 2,326 Answers
Follow the instructions from this website and you should be able to fix it.
If the instructions did not help you to fix it, there could be that the green tube is defective or a video amplifier IC on the blue CRT board.
Posted on Aug 22, 2008
  • Jaime Hernandez Aug 22, 2008
    I meant green CRT board instead of blue.
Problems with screen
It is due to power supply regulator fault. Check the main power supply regulator section circuits for any damaged [bulged] electrolytic capacitors. Replace the suspected capacitors. When replace an electrolytic capacitor, make sure about its polarity. Like torch batteries, these capacitors also have both [+ve] and [_ve] terminals, and should match it with markings at the printed circuit board, when replace them. If the polarity changes when replacing them, they might burst out. Normally, [-ve] marking will be there on its body. See the example of the suspected component. Both good and damaged. See the bulged capacitor and good one on the same frame.
Bulged [damaged]
Damaged
All of them damaged
good one with [-ve] marking
Good one with [-ve] lead marking..
Jul 12, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
The color is distorted there is a psychedelic green around. You can see the color images ok but there is a super imposed green color on the screen. Do you have any idea on the problem do I need to replace...
The tv problems u are decribing are 50/50 it could be the main board tv Tuner signal board is dying and shorting out or the tv LCD screen panel itself are leaking radiation and slowly shorting out.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish main board tv Tuner signal board for the replacement.50/50 could get this tv fixed by replacing this main board tv Tuner signal board.If after u replaced the board and still have the same problems,than u know for sure it is the tv LCD screen is dying and leaking radiation and slowly shorting out.Than u know for sure this tv is not worth as a whole tv anymore,now only as salvages tv for it PCB circuits boards only.U can return the main board tv Tuner signal board to the dealers.Get some money back,but must lose some money,like subtraction like from the shipping and handleling cost and the useually the 10% restocking fee.
Aug 14, 2011 | Proscan 40LC45S 40 in. LCD TV
Red light flashing screen is green turn off itself
your color wheel/ color main bored has gone bad (red flashing indictating one of 3 things depending on flashing. no power to main board. or to much power/bad board on one of the color boards) or you just need to replace the bulb in it. i doubt its a bulb issue bc you do see a greenness to it at first. but *** will auto shut down till the board is fixed. sorry for the bad news but this is your solution. . if you can tell me what model the tv is i cna find out exactly what it is and how many flashes.
Mar 19, 2011 | Sony Televison & Video
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
My Vizio has pixelation and blue and green colors only you can barely tell there is a definite picture but its all green or blue
Hi;
Have the digital board replaced, it might also be a good idea to replace the main board at the same time. Have a technician check the VS and VA and VE voltages to the y-Substain board also, on most plasmas there are small variable adjustments knobs that control these voltages some times this porblem can be resolved by adjusting the voltages.
Jan 30, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Bright colors bleeding onto picture
if you tried adjusting all parameters in the menu and anything you do is not resolving it, go into any workshop to have them replacing the main board. It looks ugly this idea but now days this kind or repair is posible and the board is "affordable". find any workshop close to your area. The reason of this idea is because the main board controls all parameters in the tv and the other part who we can blame on is the screen itself so if the tv is repairable (economical to repair) the workshop sure it would tell you.
Apr 08, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
RCA 52" Model D52W23 Color Distorted
its not due to the fuse.its the problem of the ic on the maIN BOARD of the tv just check out for the faulty on the main board with multi meter and replace it.
Dec 19, 2008 | Sony KP-51WS520 51" Rear Projection...
The colors red and green shifted right
the settings are on the main board the tv needs to be opened to make it clear.
Nov 07, 2008 | Soyo Televison & Video
No power at all. No amber light or green light. Power cord check out fine?? Work great then 8 hours later went to watch TV. and nothing. Any help out there ??
I've been hearing alot about the main power supply board with this model. Mostly I hear that when the power button is pressed, the relay inside will click but with no other response from the TV. This tells me that either the relay contacts are no good or that there are some serious soldering problems on the board. That would explain why it will operate for a short time then quit unexpectedly. Thermal cycling might be stressing the already weak solder joints causing intermittent contact. Personally, I'd love to get my hands on one of these boards.
If it were me and I had nothing to lose, I'd pull the main PS board and touch up the relay section by resoldering (as I believe it is more likely to have bad solder joints then the bad relay contacts). If anyone tries this with positive results, please let me know and rate accordingly.
Dec 29, 2007 | Vizio L37 Television
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
