Question about HP OfficeJet 7410 All-In-One InkJet Printer
Auto select paper
Would like to set up auto select paper from 2 trays. Documents would be 8.5 x 11 and 11 x 13 is this possible?
  • 876 Answers
I'm sorry, but you still have to tell this great piece of equipment what size paper you are loading. There are now so many types and sizes of paper. Your best bet is to keep one type of paper in one tray another in another tray and switch trays or if you have the capability choose between them, and keyin your paper size.
Have a great time with your printer and thank You for using Fix
YA.
Posted on Aug 22, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1-go to file then print right click on you printer
2-properties
3-device settings
4-select auto
Xerox WC 7530 Tray 5 is default
check the computer you are printing from. Check the printer properties when the print box comes up before you click on ok. Check the paper source setting in each computers printer settings
Aug 24, 2017 | Office Equipment & Supplies
How do I select paper tray 2
You can set the Brother machine to automatically select the appropriate paper tray based on the paper size or you can manually select paper tray1 or 2. If you use the Auto Select feature, the application will automatically pull from the appropriate tray based on the document#s paper size. For this feature to work, the tray settings must be definedfrom the machine#s control panel. For instructions on how to configure this setting, continue to the section labeled: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING)
PART 1: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING
1. On the Brother machine, press MENU.
2. Scroll to and press GENERAL SETUP.
3. Scroll to and press TRAY SETTING.
Oct 29, 2010 | Brother MFC 6490CW InkJet Printer
What's a 016-799 error code mean?
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
Oct 04, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Won't print to right tray
I had this problem and solved it like this:
  1. Right click on printer driver in printers and faxes.
  2. Select printing preferences
  3. Choose paper quality tab
  4. Set paper size (A4 in my case)
  5. Set paper source to printer-auto-select. This is different from the default "Automatically select"
As long as tray 1 is empty, tray 2 should now kick in. Setting the paper source as tray 2 didn't work at all.
You seem to have to set this on each client computer though - even if you are sharing the printer over a network (4200n).
Sep 23, 2008 | HP LaserJet 4200 Printer
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Brother MFC-8460N ... No Paper response
I had the same problem with a customer, to resolve this issue:
> Go to the printers folder
> Right click on the printer
> Go to printing preferences
> Under the paper source settings change it from autoselect to Tray1 and save the settings.
This will force the printer to print to tray1.
That fixed it for me, hope it works for you too.
Sergio Mayorga
Technical Support Representative
SACA Technologies, Inc.
Jun 16, 2007 | Brother MFC-8460N Laser Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
